250whp on a semi-built d16. What turbo can do it?
basically just what the title says. I was gonna put on the 15g on my stock d16 but I know i will upgrade in the future and if I was gonna go the hondata route I might as well go all out. I will just upgrade the rods and pistons, but I wanted to know what would be the best turbo that can support my goal.
Re: 250whp on a semi-built d16. What turbo can do it? (willyboyD16)
This one, t04e ball bearing with polished compressor housing
50 comp trim, .48 t3 exhaust, ball bearing, rated at 400whp, RAPID spool up.
PM me if you are interested in it, thanks.
Re: 250whp on a semi-built d16. What turbo can do it? (98civicEX)
t3/t04b of course this is just my opinion
This is the turbo i used to make 260whp
Brian
Re: 250whp on a semi-built d16. What turbo can do it? (TurbodCX)
screw all those get a GT28 ballbearing and will spool up quickes on your D15, compared to the ones listed above. It's ballbearing and water cooled
Re: 250whp on a semi-built d16. What turbo can do it? (Charlie Moua)
thanks for the replies
What would be the optimal a/r numbers and trims to go with if I go with the t3/t4b
[Modified by willyboyD16, 8:43 AM 2/27/2003]
Brian
Brian
Am I gonna need sleeves with this setup or can I get away with just the forged rods and 9:1 forged pistons I only plan on running around 12psi max
importdude2000
06-09-2008 07:56 PM
importdude2000
Northern California (Sales)
05-20-2008 01:25 AM
importdude2000
05-20-2008 01:20 AM
PeakBoost
12-27-2005 10:10 PM
PeakBoost
11-17-2005 07:27 AM
