what brand clutches do you guys use???
i did a search but couldnt find anything. i use to have a act heavy duty pp and 6 puck disc in my old ls but i didnt like how it chattered all the time? anyone using a sprung hub 6 puck like the clutchnet? so yeah, what brand clutches are you guys using and how many psi?
New User
Re: what brand clutches do you guys use??? (Turbo_EK)
ACT Xtreme Pressure plate, Street Disc, mated to a clutchmaster 9lb flywheel. I had it for about three years, but I think the street disc is wearing thin already. Starting to feel a slip at 6.5psi even after rebleeding the clutch lines. Someone point me in the direction for good deal on a kevlar disc
Re: what brand clutches do you guys use??? (GudeH23a)
ditto
ditto
liam
Re: what brand clutches do you guys use??? (swlabhot)
Steve. just bring the RPMs up a little more and it will go away. Mine will only chatter at real low RPMs when I under-gas it.
Re: what brand clutches do you guys use??? (2K_TEG)
Just to inform you guys, action does have a 6puck with sprung hub available. I'm running the action 2ms, which is the stage 2 with sprung hub and it has NO chatter at all. Kyle should be able to help you guys out on action stuff. Paul
Re: what brand clutches do you guys use??? (TurboD16Z6)
Re: what brand clutches do you guys use??? (liam821)
ditto also - ACT Xtreme pressure plate, street disc, jun lightweight flywheel.
I hear that ACT pressure plates have a tendence to warp over time...almost everybody that has owned an ACT with a fair amount of miles has said this. But you cant complain they last a good time and they have a great peddle feel. Id buy another one.
liam
Re: what brand clutches do you guys use??? (MikeMAN)
About to buy the Action dual P/plate with kevlar disc.... Anyone using this combo here?
