Sorry...but I'm a complete turbo n00b...
Here are my embarrasing n00b turbo questions....
1.) what is the difference between the wastegate and the turbo itself?
2.) 5 PSI is = to 5 pounds of boost per square inch correct?
3.) when using boost, is it best to have boost engaged during first gear...or wait till 2nd gear to start using the boost? It seems like you would get out of first gear way too soon to really be able to use any boost. Obviously you would have to have a boost control to do this...but ne wayz....
that concludes my embarrasing questions...plz dont laugh too hard
Re: Sorry...but I'm a complete turbo n00b... (xstalkrx)
1.) The wastegate is what controlls the amount of exhaust gases getting to your turbo. It vents out excess exhuast so you don't overboost your motor. There are boost controllers that you hook up to your wastegate to control the amount of boost you want to make. There are "internal" wastegates that are built into the turbo and "external" wastegates that install usually onto the turbo manifold itself such as a Tial, Deltagate(bad), and Hks..etc
2.)5psi = 5 pounds of pressure. PSI = pounds per square inch. There is also "Bar" 1 Bar = 14.7 lbs of boost.
3.) it doesn't matter . you can't really call upon boost like "NAWZ"....it depends on your motor setup and the size of your turbo. Your turbo spools up and is dependant on exhaust gases coming out of your motor. I guess if you didn't want boost in first gear you can get a get a boost controller to help you out with this....but I don't really see the point.
[Modified by LiLOtaku, 5:04 AM 2/28/2003]
Re: Sorry...but I'm a complete turbo n00b... (GZERO)
this is a good place to start http://auto.howstuffworks.com/turbo.htm
go here and learn some of the basics
damn...someone beat me to it
[Modified by Shady Hills, 5:15 AM 2/28/2003]
Re: Sorry...but I'm a complete turbo n00b... (Shady Hills)
Help List
https://honda-tech.com/zerothread?id=67146 -oil return
https://honda-tech.com/zerothread?id=109160 -oil return line setup
https://honda-tech.com/zerothread?id=114490 -oil return line parts
https://honda-tech.com/zerothread?id=71999 -where to weld oil return
https://honda-tech.com/zerothread?id=119100 -oil return line
https://honda-tech.com/zerothread?id=119539 -oil pan welding
https://honda-tech.com/zerothread?id=119715 -oil pan welding
https://honda-tech.com/zerothread?id=118687 -oil grade to use
https://honda-tech.com/zerothread?id=118694 -ft for oil feed line
https://honda-tech.com/zerothread?id=118807 -oil feed line
https://honda-tech.com/zerothread?id=119681 -oil feed line
https://honda-tech.com/zerothread?id=93550 -part for oil feed line
https://honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
https://honda-tech.com/zerothread?id=126335 -oil t question
https://honda-tech.com/zerothread?id=125438 -another place to buy oil lines
https://honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
https://honda-tech.com/zerothread?id=134078 -feed diagram
https://honda-tech.com/zerothread?id=133948 -oil bpst fitting again
https://honda-tech.com/zerothread?id=144586 -oil feed line restrictor
https://honda-tech.com/zerothread?id=155510 -oil leaks
https://honda-tech.com/zerothread?id=158018 -oil feed 3' better
https://honda-tech.com/zerothread?id=156571 -oil pan bolts
https://honda-tech.com/zerothread?id=170223 -oil pressure readings
https://honda-tech.com/zerothread?id=168084 -oil feed fitting
https://honda-tech.com/zerothread?id=131450 -oil feed diagram
https://honda-tech.com/zerothread?id=195068 -oil pressure
https://honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
https://honda-tech.com/zerothread?id=116891 -closed loop turbo info
https://honda-tech.com/zerothread?id=119724 -drag 3 turbo fitment (filing block)
https://honda-tech.com/zerothread?id=119690 -vacuum source
https://honda-tech.com/zerothread?id=94820 -closed loop
https://honda-tech.com/zerothread?id=120814 -Drag3 downpipe
https://honda-tech.com/zerothread?id=120867 -Drag3 + Tial connection
https://honda-tech.com/zerothread?id=118699 -wastegate vacuum line
https://honda-tech.com/zerothread?id=118767 -feul pump for drag 3
https://honda-tech.com/zerothread?id=121442 -fittings (brass T on block)
https://honda-tech.com/zerothread?id=123326 -blow off valve tightening
https://honda-tech.com/zerothread?id=123925 -catalytic converter removal o2 sensor
https://honda-tech.com/zerothread?id=124474 -'burning' in the turbo + blow off valve ?
https://honda-tech.com/zerothread?id=124580 -drag 3 manifold boost spike issues
https://honda-tech.com/zerothread?id=124662 -drag 3 tial fitment
https://honda-tech.com/zerothread?id=151845 -closed loop dump tube
https://honda-tech.com/zerothread?id=155616 -flexpipe issue
https://honda-tech.com/zerothread?id=159889 -blow off valve adjusting/cleaning
https://honda-tech.com/zerothread?id=163453 -egt probe tapping
https://honda-tech.com/zerothread?id=167329 -o2 sensor bung
https://honda-tech.com/zerothread?id=170498 -don't use tial gasket
https://honda-tech.com/zerothread?id=175270 -intercooler direction
https://honda-tech.com/zerothread?id=175277 -drag bolts suck
https://honda-tech.com/zerothread?id=206376 -bov greddy type s (loose)
https://honda-tech.com/zerothread?id=120548 -hondata install (solder stuff)
https://honda-tech.com/zerothread?id=98092 -hondata install heiarchy
https://honda-tech.com/zerothread?id=121859 -hondata info on pumps
https://honda-tech.com/zerothread?id=117300 -spark plugs
https://honda-tech.com/zerothread?id=156273 -spark plugs (2)
https://honda-tech.com/zerothread?id=116886 -changing plugs
https://honda-tech.com/zerothread?id=117326 -flexpipe for good price
https://honda-tech.com/zerothread?id=117733 -injectors, 440 or 550
https://honda-tech.com/zerothread?id=119569 -guage for autometer
https://honda-tech.com/zerothread?id=119591 -autometer guages
https://honda-tech.com/zerothread?id=121452 -aero fpr
https://honda-tech.com/zerothread?id=119884 -best FPR?
https://honda-tech.com/zerothread?id=118885 -place to buy aem fpr
https://honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
https://honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
https://honda-tech.com/zerothread?id=120889 -profec b install
https://honda-tech.com/zerothread?id=116651 -Radiator fans
https://honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
https://honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
https://honda-tech.com/zerothread?id=122396 -block guard
https://honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
https://honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
https://honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
https://honda-tech.com/zerothread?id=125639 -hks ssbv clip
https://honda-tech.com/zerothread?id=153531 -more hks bov install
https://honda-tech.com/zerothread?id=125852 -carsound cat part #
https://honda-tech.com/zerothread?id=92570 -turbo timer relay
https://honda-tech.com/zerothread?id=128321 -turbo timer wiring
https://honda-tech.com/zerothread?id=132485 -radius rods
https://honda-tech.com/zerothread?id=63095 -rear seat removal
https://honda-tech.com/zerothread?id=133644 -injector fitment
https://honda-tech.com/zerothread?id=104940 -thermal to cat issues
https://honda-tech.com/zerothread?id=136680 -egt guage stuff
https://honda-tech.com/zerothread?id=137223 -which runner to tap for egt
https://honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
https://honda-tech.com/zerothread?id=139706 -tools to carry
https://honda-tech.com/zerothread?id=140003 -base fuel map
https://honda-tech.com/zerothread?id=140774 -bleeding coolant
https://honda-tech.com/zerothread?id=156073 -js safeguard
https://honda-tech.com/zerothread?id=168470 -js safeguard, who is using
https://honda-tech.com/zerothread?id=160428 -summit part
https://honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
https://honda-tech.com/zerothread?id=170821 -wires to tap for guages
https://honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
https://honda-tech.com/zerothread?id=171314 -EGT temps
https://honda-tech.com/zerothread?id=166449 -vacuum sources
https://honda-tech.com/zerothread?id=175335 -assembling an fittings
https://honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
https://honda-tech.com/zerothread?id=193263 -greddy profec b
https://honda-tech.com/zerothread?id=85987 -installing rc injectors
https://honda-tech.com/zerothread?id=106033 -matching wires rc injectors
https://honda-tech.com/zerothread?id=133644 -fitment of rc injectors
https://honda-tech.com/zerothread?id=107030 -polarity does not matter
https://honda-tech.com/zerothread?id=154935 -once installed
https://honda-tech.com/zerothread?id=159623 -tips to install
Re: Sorry...but I'm a complete turbo n00b... (smallttocs)
Help List
seriously just stick reading threads here and in a couple of weeks you'll learn a lot.
HT's Biggest Loser
HOLY ****! somebody did their homework. lol well if that guy doesnt learn anything by reading the 43978 posts you just linked him to, then god help us all
If you watch "The fast and the furious" or "2fast 2furious" disregard anything they say about cars or tuning.
You'll be a much wiser person for doing this. HEED MY WORDS YOUNG GRASSHOPPER!
Re: Sorry...but I'm a complete turbo n00b... (Infinity_Racer)
I've got a Q.
So why is 10psi on a T25 different from 10psi on a straight T04?
isn't 1psi = 1psi?
isn't 1psi = 1psi?
1 Post
Re: Sorry...but I'm a complete turbo n00b... (buh_buh)
pressure is different from volume.
Bad example, but you'll get the idea:
You can inflate a bike tire to 60 psi, or a semi truck tire to 60psi. Same pressure, MUCH more volume.
isn't 1psi = 1psi?<<
All turbos have graphical representations of their efficiency ranges. the up/down axis is boost pressure, and the left/right axis is the volume of air. The graphs end up resembling a target sort of, with the "sweet spot" (most efficient zone) of the turbo being represented by the "bullseye". A T25 has a different efficiency range from a T04. It's a smaller turbo, so it's efficient at a lower "volume" of air, measured in cubic feet per minute our lbs per minute.
In a way, you're right. 1psi is 1psi. What happens essentially is that the smaller T25 is not as efficient at moving large amounts of air as a T04, so while boost pressure is the same at some hypothetical point, the *charge temperature* from the T25 will be a lot higher. The temperature difference is really the primary reason why a T25 at 15 psi makes less HP than a T04 at 15 psi.
That said, I've got a T25 on my D16Y8 and it's fantastic.
