tapping manifold for egt probe?
Old Feb 27, 2003 | 08:37 PM
T25 civic's Avatar
Default tapping manifold for egt probe?
I heard it was possible to tap the manifold while the car was running, with the turbo still attached? Is this true? The reason I'm asking is my new manifold that I put on a week ago to move the car out of the garage now has a stripped bolt and I can't seem to get it out! I'm tired of ******* with it and I was wondering has anyone done this?
Nick
Old Feb 27, 2003 | 08:46 PM
CzanSOHC's Avatar
Default Re: tapping manifold for egt probe? (T25 civic)
i doesn't seem like a good idea to me...
Old Feb 27, 2003 | 08:57 PM
rondigs's Avatar
Default Re: tapping manifold for egt probe? (CzanSOHC)
If you have to drill/tap a hole into the manifold (without taking it off)...where are all the metal shavings going to go?
[Modified by rondigs, 5:58 AM 2/28/2003]
Old Feb 27, 2003 | 08:58 PM
T25 civic's Avatar
Default Re: tapping manifold for egt probe? (rondigs)
well I was told that with the car running it would blow the shavings out.
nick
Old Feb 27, 2003 | 10:43 PM
CzanSOHC's Avatar
nick
it's going to blow them straight into the turbine
Old Feb 27, 2003 | 11:50 PM
inspyral's Avatar
Some of the DSM guys do it with the manifold ont he car and the engine running. They say the shavings are small enough to pass thru the turbine without hurting anything. I would assume they aren't running cats, though, since the shavings would definitely get stuck in the cat. I would just work on getting your manifold off, since you're going to need to do that sometime. Might as well fix it now. Or, you could pput your EGT probe in the downpipe. Or, if you have a T3 turbine, you can put it in the dp flange pointing into the w/g hole.
Old Feb 28, 2003 | 01:31 AM
swlabhot's Avatar
nick
[/QUOTE]it's going to blow them straight into the turbine [/QUOTE]
Old Feb 28, 2003 | 05:42 AM
PM-Performance's Avatar
Default Re: tapping manifold for egt probe? (swlabhot)
i woldnt do itmann .
i tapped mine and found out the hard way the threads didnt hold too long, i gotta take my mani out and get it welded in now. it leaks. from that probe
Old Feb 28, 2003 | 11:21 AM
GZERO's Avatar
how about taking the turbo off, tap for the EGT probe, and use a vacuum cleaner to suck as much as you can, then, turn the car on for like 2 sec so it will blew all the shavings out of the manifold, i know this sound scrazy, but it'll do the job
Old Feb 28, 2003 | 11:55 AM
CzanSOHC's Avatar
Default Re: tapping manifold for egt probe? (GZERO)
Old Feb 28, 2003 | 12:07 PM
GZERO's Avatar
dude, read, he said manifold bolt, NOT TURBO bolt
[Modified by GZERO, 4:08 PM 2/28/2003]
Old Mar 2, 2003 | 01:02 PM
T25 civic's Avatar
its all right now, I just had to keep messing with that damn bolt. I finially got it off and I have it tapped now. Thanks for the replies.
Nick
Old Mar 2, 2003 | 01:03 PM
T25 civic's Avatar
wow, I just noticed, why the hell am I at 98%? whats that all about?
Old Mar 2, 2003 | 01:21 PM
MachAF's Avatar
Nick
whoever told you that was an idiot.
Old Mar 2, 2003 | 02:45 PM
inspyral's Avatar
Default Re: tapping manifold for egt probe? (machaf)
RRE does that:
http://www.roadraceengineering.com/i...structions.htm
Old Mar 2, 2003 | 02:57 PM
DeepSi's Avatar
Default Re: tapping manifold for egt probe? (inspyral)
A lot of the DSM people drill the manifold while the car is running. I dont recommend it, but people do it. If you are going to do it, here are somethings to help you out. (tips taken from reading the DSM boards):
1. drill slowly
2. take cat off
3. always have car running
4. Might want to use grease on the drill bit to help catch some of the filings.
hope this helps.
Blove1991
Dec 19, 2011 06:50 PM
jimmy051702
May 12, 2011 08:50 PM
wade
Jun 28, 2005 08:59 PM
Blindstuff
Oct 5, 2004 06:33 PM
