calculus applied to motors.....
Old Feb 27, 2003 | 12:46 PM
keebler65's Avatar
Default calculus applied to motors.....
i was working on a word problem for calculus and it had to do with the movement of pistons in a car. i thought it was really interesting. it basically explains how much forces increase on moving parts as you increase the speed of the motor.
for those of you that care, the formula is s=A*cos(2*Pi*b*t)
where A is amplitude of motion, b is frequency (# of times the piston moves up and down each second), and t is time in secs.
anyways, i found out the following:
if we double the frequency (rpm), that causes the velocity to double (which isnt very impressive...)
if we double the frequency (rpm), that causes the acceleration of the piston to quadruple. (thats fast...)
if we double the frequency (rpm), that causes the jerk (the stress caused by the piston changing direction rapidly) to be multiplied by a factor of 8 (ouch!)
i felt it kind of put things into perspective. at the very least, it made my class interesting for once. maybe you'll think twice before going to the redline next time
Old Feb 27, 2003 | 12:56 PM
filetofit
Guest
Posts: n/a
Default Re: calculus applied to motors..... (keebler65)
You want a really good calculus problem, calculate the piston speed as a function of crank RPM.
Old Feb 27, 2003 | 05:39 PM
DefiantGSR's Avatar
Default Re: calculus applied to motors..... (filetofit)
ill give anyone the answer if you pay me 10 bucks. hah.
Old Feb 27, 2003 | 07:08 PM
lazerus's Avatar
Default Re: calculus applied to motors..... (DefiantGSR)
then calculate the amount of stretch iron rods see at rev limiter.
then calculate for Titanium.
think about how you can make more power
Interesting!
[Modified by lazerus, 8:09 PM 2/27/2003]
Old Feb 27, 2003 | 07:38 PM
Burke's Avatar
Banned
Default Re: calculus applied to motors..... (lazerus)
same thing for air drag. double the speed, quadruple the drag force of the air. its all due to the low pressure behind your car. whats you major??? Mechanical engineer???? well it should be!!!
later
Old Feb 27, 2003 | 07:50 PM
ZCHF's Avatar
Default Re: calculus applied to motors..... (Burke)
how about taking the force my''=mg-cy'. And then start by taking the triple integral of e^x. hahaha. i love math. its one of those things that is just great.
Old Feb 27, 2003 | 07:56 PM
earl's Avatar
Default Re: calculus applied to motors..... (ZCHF)
RPM=Ruins People's Motors
Never made it past trig...
Old Feb 27, 2003 | 08:23 PM
Tinker219's Avatar
Default Re: calculus applied to motors..... (earl)
I made it halfway through calc. in HS, then dropped it. I then tested into a math class for college that is equivalent to what I took my freshman year...go figure.
college blows, I dont think Im going back....
craigbrk
Sep 18, 2006 05:13 PM
91integraLSVTEC
Feb 15, 2004 03:53 PM
Zeus Zore
Oct 4, 2002 07:50 AM
Elex
Feb 27, 2002 11:14 AM
HXMan
Sep 27, 2001 12:15 PM
