is it bad running without chargepipe connected?
Old Feb 26, 2003 | 01:53 AM
_Endless_'s Avatar
Default is it bad running without chargepipe connected?
i just had my engine overhauled and i'm breaking it right now. i don't like putting back the turbo until the break-in period is over, but i'm running an open header right now coz the exhaust pipe was made especially for my downpipe.
since it's an open header, you could imagine how loud it is and it is getting very annoying so i'm thinking of putting my turbo back in and stay out of boost so i ask my mechanic about my plan and he said i can put back the turbo but leave the chargepipe out and use seperate intake on the t/b and just put a filter on the compressor inlet. will this setup damage the turbo? if so, in what way and why?
any help will be appreciated.
Old Feb 26, 2003 | 03:40 AM
Hybrid's Avatar
Default Re: is it bad running without chargepipe connected? (_Endless_)
You shoulden't have any problems there, just don't boost the turbo thats all. Also make sure you have all the charge and intake pipes filtered so you don't suck in any unwanted items.
You obviously still have to hook the oil lines and what not up to the turbo just as if you were going to boost.
Old Feb 26, 2003 | 04:13 AM
Kevin's Avatar
Default Re: is it bad running without chargepipe connected? (Hybrid)
Is there any particular reason why people dont break in cars under boost? When you buy a new turbo car from the factory, you break it in under boost. I would be more concerned with washing out the cylinders due to a rich condition and keeping the motor out of high boost, high rpm situations.
Old Feb 26, 2003 | 05:15 AM
zojirushi's Avatar
your gonna wanna take out the wastegate spring cuz u don't want to overspin the turbo.
Old Feb 26, 2003 | 06:47 AM
I Like Boost's Avatar
Default Re: is it bad running without chargepipe connected? (zojirushi)
Be careful, i broke in my new block with my new turbo kit installed, big mistake. i guess i wasn't careful enough because i started to notice oil in my charge pipe, it just got worse and worse. Now when the break in period was over the seals were gone on the turbo and i couldn't even boost alot because of the large amount of oil in the charge pipe, it would shoot out of the blow off valve. if the oil gets into the intake manifold and mixes with gas it will lower the octane. when boosting that is a very bad thing, boost+low octane=detanation.
Old Feb 26, 2003 | 12:54 PM
93 VTEC's Avatar
Default Re: is it bad running without chargepipe connected? (IMPULSE B18C-T)
Your turbo will spin to infinity and beyond. You will need to somehow make the wastegate see boost or just remove it completely, but then you will again have a loud exhaust. I say just leave it how it is.
Old Feb 26, 2003 | 03:19 PM
UberTeg's Avatar
Default Re: is it bad running without chargepipe connected? (93 VTEC)
cover up the compressor inlet and outlet very securly, then disconenct the wastegate so it opens freely.
Old Feb 26, 2003 | 04:14 PM
BoostedSi's Avatar
Default Re: is it bad running without chargepipe connected? (UberTeg)
dont take the chargepipe off. just drive it very easy.
Old Feb 26, 2003 | 04:40 PM
GruvyTune's Avatar
New User
Default Re: is it bad running without chargepipe connected? (BoostedSi)
agreed
Old Feb 26, 2003 | 05:59 PM
Dr Drew's Avatar
Default Re: is it bad running without chargepipe connected? (GruvyTune)
don't drive the car w/o the charge piping connected or you'll over rev your turbo and burn it up. I'd just drive it open header for a while till you get a few hundred miles on it then slap on the turbo for the remaining breakin time, just dont boost heavily and you'll be fine.
Old Feb 26, 2003 | 06:59 PM
_Endless_'s Avatar
i don't get why i should take the wastegate off if i won't be boosting.
anyway, just to be on the safe side i guess i'll just go with the open header.
thanks guys.
Old Feb 26, 2003 | 07:57 PM
turb's Avatar
so is it better to break the engine in with boost? just don't boost that often?
i've read in a thread here about breaking in an engine, some say it's better to break it in with boost..some say don't boost..so which is the right thing to do?
Old Feb 26, 2003 | 08:05 PM
Diego Boost's Avatar
Default Re: is it bad running without chargepipe connected? (turb)
There is nothing wrong with breaking in your motor with the turbo on!! Just be easy on it just like you would with n/a and ease into boost as the milage goes up. There have been tons of posts regarding the pros of breaking in your motor with the turbo on, AEBS advised me on how to break my motor in with mine on and it runs flawlessly, no smoke, no oil. Now, if your A/F is not set right and you detonate while seating your rings it will screw it up, so keep that in mind.
[Modified by Diego Boost, 5:06 AM 2/27/2003]
Deo
Apr 10, 2011 10:08 AM
thalwr1
Feb 2, 2009 12:54 PM
TVietEBoyG
Aug 14, 2007 04:30 AM
XES
Oct 19, 2005 05:50 PM
sykotic
Mar 15, 2005 03:05 PM
