Need help on which Hondata to Choose
Old Feb 26, 2003 | 12:19 PM
JohnysZC's Avatar
Default Need help on which Hondata to Choose
Hello there, im in the market to buy a Hondata now, finally I can afford one, and wanting to know which to get.
here is my setup and info. needed if anyone wants to lend a hand.
91 Civic Sedan
ZC engine stock interals with GReddy TD04 on 7psi, have both an 89 Teg ECU and ZC ECU. OBD0
Would it be the Hondata 2B with boost option?? TIA
Old Feb 26, 2003 | 02:59 PM
JohnysZC's Avatar
Default Re: Need help on which Hondata to Choose (JohnysZC)
bizzump.
did a search but nothing in relation to ZC or OBD0
Old Feb 26, 2003 | 04:31 PM
GruvyTune's Avatar
New User
if youre not doing your own tuning, get an s100 with boost option. simply the best most affordable option for daily driven turbo.
Old Feb 26, 2003 | 04:42 PM
B18Flip's Avatar
Default Re: Need help on which Hondata to Choose (GruvyTune)
yup thats the route i'm going
Old Feb 26, 2003 | 04:47 PM
VaporTrail's Avatar
New User
you have to use a stage 2,3, or 4, s100/200 will not work with pre obd. Cant use your ecu, has to be a pr3 or pw0
Old Feb 27, 2003 | 07:43 AM
JohnysZC's Avatar
Default Re: Need help on which Hondata to Choose (VaporTrail)
So idely it would be best to use 2B with boost, or should I get the 3B with more options?? Plus looks like they recomend to upgrade the Injectors from stock to bigger and an in-tank fuel pump not an in-line.
Thanks, now I have a better idea on what to get.
Old Feb 27, 2003 | 09:24 AM
VaporTrail's Avatar
New User
read the website there is a LOT of information on there
Old Feb 27, 2003 | 10:13 AM
JohnysZC's Avatar
that's exactly what I did, but wasn't sure, just had to double check and make sure of which one I need.
CRXLST
Nov 23, 2004 07:39 AM
22boost
Nov 11, 2004 01:29 PM
QuarterMileMaster
10
Aug 28, 2004 05:54 PM
Garrett
Oct 12, 2003 01:05 PM
boosted_zc
Jan 24, 2003 07:30 PM
