Questions on ZDYNE ECU! please help
just wanna know how, if its even possible, the zdyne super ecu gold ecu would work on a 94 obd1 integra RS. maybe i didnt read it right, but is it only availiable for the vtec ecus?? would it be at all reliable with a non vtec b18b1??? thanks for your help!
Re: Questions on ZDYNE ECU! please help (Acura_I-RS)
sure it is possible...a friend of mine is using a zdyne to control his turbo type r teg. you need to know that zdyne is only OBD0 which means that you would need to convert the ecu harness to OBD0 plugs AND use an OBD0 distributor(yes they are different internally sensor resistance-wise). super ecu gold allows for vtec or non-vtec operation as well as a few other things.
Re: Questions on ZDYNE ECU! please help (seekerONE)
The Zdyne works so well, It is worth doing the conversion to 0BD-0. Now if you can find some one to make the harness.
