open/closed loop with hondata & vtec?
Old Feb 27, 2003 | 04:19 PM
PM-Performance's Avatar
Default open/closed loop with hondata & vtec?
if we left my map in opn loop would that cause vtec to not engage? my car hasnt been engagin vtec since we changed the maps up and i rememebr we left it in open loop
Old Feb 27, 2003 | 04:45 PM
ekb18c's Avatar
Default Re: open/closed loop with hondata & vtec? (itr206)
Open and closed loop has nothign to do vtec. Just make you sure you didn't disable vtec. On the s200 there is an option where you can disable vtec. Just make sure that option isn't check off. Also you might want to see where vtec is suppose to engage.
How do you know your not hitting vtec by the way?
Old Feb 27, 2003 | 04:47 PM
Default Re: open/closed loop with hondata & vtec? (ekb18c)
im assuming , its not hittnig Vtec, it doesnt sound like it is and doesnt give me the little kick in the groin like it dd befrope . i tohught open /closed loop did somerthng with sensors or something ?
i have te 4b
i think we set the vtec back to stock settings
Old Feb 27, 2003 | 04:53 PM
ekb18c's Avatar
Closed and Open loop has to do with the 02 sensor. Closed loop means the ecu uses the 02 sensor to adjust.
edit- You really don't notice vtec while boosting as much as NA.
[Modified by ekb18c, 5:55 PM 2/27/2003]
Old Feb 27, 2003 | 04:55 PM
boosted hybrid's Avatar
Your turbo is spooling up quicker than before, so boost is hitting around 4,500rpm and your vtec is set 5800rpm on the map. You probably wont notice that vtec is engaging. I never hear it engage on my engines.
Old Feb 27, 2003 | 05:00 PM
Default Re: open/closed loop with hondata & vtec? (boosted hybrid)
hmm i har dit before, but ok , well w can actually see it go into high sppeed cam on the map right? well i guess we'll check it then , does that mean vtec is engaging thne when it crosses over to hisg cam? or whatever you cvall it
Old Feb 27, 2003 | 05:02 PM
When it switches over to the high speed cam map it is engaging into vtec.
[Modified by boosted hybrid, 9:02 PM 2/27/2003]
Old Feb 28, 2005 | 09:01 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
to bring it back from the dead, and not open a new thread... i have a question.
alittle background...
dont' ask why, but i have a turbo Z1.. yes a VX.. and i converted to a P28 and im running uberdata... now i have it tunned in the range of 5-7 PSI, but i haven't fiddled with the lower maps.. esspecially in vaccumm. the VTEC is set as low as possible to satisfy the E-VTEC, and on the freeway its really really rich. 10.0 A/F.
so my question.
IN VTEC, does the ECU, programed or not go into open loop reguardless?
today driving on the freeway.. i saw the gas neddle plumit.. untill i pulled over, with the "J1" switch, and baby'ed it out of spool to not throw the MAP. (no boost)
at this time.. on the stock ECU ROM, it ran fine.. 14.2 - 14.9 A/F give or take.
Modified by Built B16A at 9:46 AM 3/1/2005
Old Mar 1, 2005 | 08:45 AM
Built B16A's Avatar
still looking for that answer.
DXDOHCVTEC
Jul 29, 2004 10:34 PM
xvracing
May 1, 2004 01:49 PM
civickid03
Mar 25, 2004 11:00 AM
