Eight 450cc injectors complete
Old Feb 25, 2003 | 12:07 PM
Tinker219's Avatar
Default Eight 450cc injectors complete
I just drilled and tapped the holes for the barbed fittings(1/8 pipe thread), used high pressure oil hose(350psi), and connected everything with hose clamps. The hose was a bitch to get over the injectors, so there is no way that the hose is going to pop off. I just have to trim the mounting brackets around each injector a little more so that the injector plugs will snap on without interference...
Old Feb 25, 2003 | 12:20 PM
genop's Avatar
Default Re: Eight 450cc injectors complete (Tinker219)
That looks really nice! What kinda numbers are you trying to get from that??
Old Feb 25, 2003 | 12:25 PM
Tinker219's Avatar
Default Re: Eight 450cc injectors complete (genop)
well, read my sig...Im not sure what kind of numbers...Im just trying to go as fast as I can with my income If I had to pick a goal, I want to see 500whp eventually. With the stock head that I will be running(for now), I want to see 350whp. I think that will be reached easily, but I dont want to set my standards too high...
Anybody know what the thread pitch/size is on the Venom fuel rail? I want to order through summit/jegs to save money, but if I dont know the size, i will have buy local. The only place that can get stainless braided lines wants $65 for 3 feet of 8-an hose for example...
jinxproof99's Avatar
New User
i'd invest in a new pump. the 255 will support 500+ but a bigger pump would be safer.
Old Feb 25, 2003 | 12:31 PM
Tinker219's Avatar
Default Re: Eight 450cc injectors complete (jinxproof99)
Im just gonna run the walbro till it pukes...from what Ive been hearing, it only takes a year or so...
Old Feb 25, 2003 | 02:00 PM
Smashback's Avatar
WHAT?!?! The most you should have to pay is $10 a foot for -8 and that's high.
Anyway, I'd be willing to bet that the Venom uses -8 AN ports like most others out there. Now these are not flare fittings like hose ends screw onto... what you'd need is this...
http://store.summitracing.com/partdetail.asp?part=35000
[Modified by Hatchblack, 11:01 PM 2/25/2003]
Old Feb 25, 2003 | 02:04 PM
liam821's Avatar
25 Year Member
thats pretty cool good luck with that. How are you going to be powering it? mf2? hondata? ems?
liam
Old Feb 25, 2003 | 02:05 PM
New User
Default Re: Eight 450cc injectors complete (Hatchblack)
str, inlinepro, and i believe golden eagle all make them with 10an fittings.
Old Feb 25, 2003 | 02:15 PM
K20Ahondas's Avatar
Why not make it easy and go with four 720cc.
Old Feb 25, 2003 | 02:23 PM
Smashback's Avatar
I have one of the new STR rails and it uses -8...I think GE's claim to fame is the -10 but I can't imagine who needs it
Old Feb 25, 2003 | 02:25 PM
New User
my older str rails were 10an.
Old Feb 25, 2003 | 02:34 PM
Cramerox's Avatar
can anyone tell me why run 8 injectors? Arnt there higher cc injectors out there?
Old Feb 25, 2003 | 02:47 PM
liam821's Avatar
25 Year Member
Default Re: Eight 450cc injectors complete (1FSTCAR)
I think price played a huge roll. 8 450cc are either free-$100 depending on where ya go. 4 720s are $400 or more.
liam
Old Feb 25, 2003 | 02:59 PM
MikeMAN's Avatar
Default Re: Eight 450cc injectors complete (liam821)
liam
Old Feb 25, 2003 | 04:37 PM
93LSivic's Avatar
Default Re: Eight 450cc injectors complete (MikeMAN)
Thats like a ghetto old school AIC setup! I dont see how it will perform well, you will have a lit of problem with fuel puddling since those injectors are shooting right into the runners.
You get a for effort though.
Old Feb 25, 2003 | 05:05 PM
tony1's Avatar
We run dual -12 feed into the rails and -10 returns to the regulator! I guess that's not your typical application though.
On the manifold shown, you want to fire the additional injectors with the airstream like the stock ones are. Firing them perpendicular to the airflow will disrupt airflow quite a bit. Something to think about....
Old Feb 25, 2003 | 05:52 PM
Tinker219's Avatar
Default Re: Eight 450cc injectors complete (tony1)
I plan on making some blocks that will tilt the injectors back a little to fire with the airflow like indicated. I just need to find somethign that is easily drill-able. Once I get my TIG welder(very very soon now), I will probably weld the blocks on along with a better mounting design...
as for the other questions, yes 8 450s are cheaper than one 720cc injector Of course my EMS offset that price a little bit, but I think the EMS is what is going to get me the most HP...as far as I know, Hondata wont control 8 injectors(in a "secondary" orientation anyway). Thank you all for the good responses...
Oh ya...people that are running methanol almost HAVE to use more than 4 injectors because they dont make an injector big enough to support the flow needed, and idling would be next to impossible with such big injectors(ie, 1600cc).
Any of you dealers sell braided hose, fittings?
Old Feb 25, 2003 | 08:03 PM
Tinker219's Avatar
ttt
TylerB
Feb 22, 2010 03:51 PM
sevenj
May 21, 2008 04:50 PM
eg_gsr11
Jun 16, 2006 04:35 AM
reXem
Feb 3, 2003 12:12 PM
