just received maxrev manifold
The manifold is awesome. The welds are great. Looks much better than the Drag and a custom manifold I had before. Thumbs up for Curtis and maxrev.
Re: just received maxrev manifold (foozball-26)
what's the easy fix for the dp?
My maxrev mani needs more machine work like milling and grinding and welding before I would even consider putting it on...
New User
Re: just received maxrev manifold (Pat)
Yea getting a bolt in the bottom one is going to be a bitch. I use a stud/bolt kit to hold my downpipe in place. Works great, but at this point I am only using three out of the four studs...no problems at all
Re: just received maxrev manifold (lshatchturbo)
its simple all you need is an extra stud like the ones that hold your header on (the ones that screw into the block) and a nut for it. Done
