Boosted D16 Lean....
Old Feb 26, 2003 | 06:47 AM
BDTURBO's Avatar
Default Boosted D16 Lean....
My boosed D16z is running lean and I was wondering if I can cange that with my V-AFC hack?
Old Feb 26, 2003 | 09:09 AM
brcivic411's Avatar
Default Re: Boosted D16 Lean.... (BDTURBO)
what are your current afc settings?
Old Feb 26, 2003 | 09:26 AM
BDTURBO's Avatar
Default Re: Boosted D16 Lean.... (brcivic411)
all i use it for is vtec engagement but now that i have a turbo i have to use if for fuel and air
Old Feb 26, 2003 | 09:27 AM
Daniel's Avatar
yeah, you can change your lean condition using the hack setup. what is your current fuel management? just the VAFC?
Old Feb 26, 2003 | 11:41 AM
BDTURBO's Avatar
Default Re: Boosted D16 Lean.... (Daniel)
yes, just the VAFC, today i put in a turbo eclipse fuel pump to help with the fuel and added 1% fuel throughout the whole RPM gauge, do you think that will fix it
Old Feb 26, 2003 | 11:44 AM
genop's Avatar
what are your afc settings and what size injectors are you running??
Old Feb 26, 2003 | 12:01 PM
BDTURBO's Avatar
Default Re: Boosted D16 Lean.... (genop)
stock injectors, the only VAFC setting is 1% fuel increase
Old Feb 26, 2003 | 12:22 PM
98civicEX's Avatar
go get some 450s or 440s, and you can say bye bye to being lean, if anything you'll be running rich w/ the hack. I had to clean off all the soot from the exhaust every other day.
Old Feb 26, 2003 | 03:41 PM
BDTURBO's Avatar
Default Re: Boosted D16 Lean.... (98civicEX)
thanks, but if i start to run to rich can i lean it back with my vafc?
Old Feb 26, 2003 | 04:14 PM
technine's Avatar
You better get some type of fuel management before your motor go's bye, bye. I don't have the hack, but yes you can lean out the fuel mixture with it.
Old Feb 26, 2003 | 04:45 PM
MikeMAN's Avatar
depends on how lean ur running, I would add 10% fuel across the board and start from there.
good luck!
mike
Old Feb 27, 2003 | 10:49 AM
BDTURBO's Avatar
Default Re: Boosted D16 Lean.... (MikeMAN)
UPDATE: i added 2% increase across the board with a turbo eclpise fuel pump, so good so far!
Old Feb 27, 2003 | 10:56 AM
Licensed2Spool's Avatar
Before my D16 blew, I was using a v-afc with vortec rising rate regulator, jackson racing fuel pump, and stock injectors. The shop was able to tune it perfectly.
integra15
Mar 21, 2005 12:05 PM
b20turbojason
Aug 7, 2004 04:58 PM
Firewerks
Jul 4, 2004 07:02 AM
wontonracer
Mar 16, 2003 06:05 PM
EK9Blitz
Oct 3, 2002 10:52 PM
