almost done turbocharged 95 gs-r 4dr. just waiting on my hondata to come back !!!!!
Almost happy, my install is almost done!! Tell me what you all think.
b18c1
srp pistions
eagle rods
block guard
ferrea valves 0.5 oversized
3 angle valve job
polished head
max-rev turbo kit
t3/t04e garret turbo
rc 440 injectors
s200 hondata ecu
@8psi
turbonetics boost control
large front mount intercooler
pics as followed:::
prime the turbo or not prime the turbo that is the question please help out?
some say yes some say no what is the real answer?
have not started the car yet waiting on the s200 haondata to come back with the base map.
b18c1
srp pistions
eagle rods
block guard
3 angle valve job
polished head
max-rev turbo kit
rc 440 injectors
s200 hondata ecu
@8psi
pics as followed:::
Re: almost done turbocharged 95 gs-r 4dr. just waiting on my hondata to come back !!!!! (Diego Boost
1. Nice car.
2. You have a great reason to get a bigger intercooler.
3. Why only 8lbs?
4. When you say prime the turbo, do you mean pulling the starter power, cranking the car, and filling the oil feed line w/ oil? Or do people suggest mannually putting oil in the turbo like you would an oil filter? I know to do the earlier, i have heard nothing about the latter.
[Modified by BoostedGSRBubble, 12:05 AM 2/27/2003]
3. Why only 8lbs?
please remove that front bumper, but the turbo kit looks nice!
yes, prime the turbo. Pull out the spark plugs and crank the motor. Make sure the oil is getting to the turbo by pulling out the oil return line to see if the oil is coming out of it. Make sure you have something for it to drain into.
Re: almost done turbocharged 95 gs-r 4dr. just waiting on my hondata to come back !!!!! (vtecpwred)
looks good. I'd get some more custom pipe and move your air filter so it sucks up colder air. Looks like it'll be sucking all the hot air up off the turbo.
Could you please post what that MaxRev BOV sounds like when you finally start it?
Thanks
Bryson
Thanks
Bryson
Re: almost done turbocharged 95 gs-r 4dr. just waiting on my hondata to come back !!!!! (Bryson)
Thanks alot guys. I was going to my pipes done by a pro, but did not want to pay the high price. filter location will change later .
Very nice setup. Is that a maxrev intercooler? To tell you the truth, that bumper looks ok with a nice big intercooler sitting in it nice work
-Ryan
p.s. what size turbo are you running and was it necessary to grind anything off the motor/radiator fans?
[Modified by tegasaurus, 6:48 PM 2/27/2003]
-Ryan
Re: almost done turbocharged 95 gs-r 4dr. just waiting on my hondata to come back !!!!! (tegasaurus)
The turbo size is t3/t04E both fans had to be trimmed, block notched,A bitch to get a filter on ,But I feel it will all be worth it !!!
MAX-REV performance Thanks.................
vtecpwred
04-02-2003 05:42 PM
