need help with check valves
Old Apr 30, 2003 | 02:15 PM
W.Zero's Avatar
Default need help with check valves
im putting on a turbo kit for my friend that has a crx with a 1st gen b16a motor. cant seem to figure out how to install the check valves. can any one help me please. ive search but all i found was how to them on a 2nd gen B series. or if anyone know of a site? thanks
Les
Old Apr 30, 2003 | 02:16 PM
Tinker219's Avatar
Default Re: need help with check valves (W.ZeroB18C1T)
umm...use 4 t's on the vacuum line, and fit a check valve on each?
Old Apr 30, 2003 | 02:34 PM
Pengo's Avatar
T off as many times as u want on the vacuum line right before the map sensor and have a check valve on each T.
Old Apr 30, 2003 | 02:47 PM
DIRep972's Avatar
Smarter than you
Best place to put check valves is in the trash. Have ur friend buy a missing link and save himself some hassles when the check valves don't work and ur ecu sees boost.
Old May 1, 2003 | 01:33 PM
W.Zero's Avatar
Default Re: need help with check valves (Mr. Belding)
the only thing is, there's no map sensor. his car is obd0. theres alot of vaccum line off his throttle body. just need to know which one to tap.
bennyhonda7
May 11, 2005 11:38 AM
turbohybridhatch
Mar 17, 2005 07:05 PM
Integra_Boi
Aug 11, 2002 07:03 PM
integraracer94
Jun 2, 2002 06:34 PM
turbotec
Feb 26, 2002 03:34 PM
