dosnt pull
Old May 3, 2003 | 01:31 PM
B18C1CYA's Avatar
Default dosnt pull
I have a drag gen 3 turbo on my gsr and boost is like 11psi .
some times in the high revs it feels like it dosnt pull hard any more like it leavels off almost . could this be because the wastegate is fully open or could it be running to rich?
Old May 3, 2003 | 01:38 PM
Tinker219's Avatar
Default Re: dosnt pull (B18C1CYA)
most likely too lean. read the plugs.
Old May 3, 2003 | 01:59 PM
intekragsr's Avatar
fuel setup?
Old May 3, 2003 | 02:03 PM
B18C1CYA's Avatar
Default Re: dosnt pull (intekragsr)
stock pump , inline, fmu, stock injectors i have a msd btm what should i set that dail to for 11psi
Old May 3, 2003 | 02:08 PM
dfoxengr's Avatar
i degree retard for every lb...
Old May 3, 2003 | 02:21 PM
ninesecrx's Avatar
Default Re: dosnt pull (hybridvteceg)
how long has the kit been on? Maybe your just getting used to the power? Thats what sucks, doenst matter how much power your making or how fast it is...you will get used to it.
Old May 3, 2003 | 03:06 PM
Acura_I-RS's Avatar
Default Re: dosnt pull (ninesecrx)
stock injectors????
Old May 3, 2003 | 03:07 PM
dfoxengr's Avatar
Default Re: dosnt pull (Acura_I-RS)
yeah i missed that...drop those immediately
Old May 3, 2003 | 04:03 PM
B18C1CYA's Avatar
drop the stock injectors what if i do the afc hack with dsm 450s and ditch the fmu will that work?
Old May 3, 2003 | 04:22 PM
drvfast's Avatar
yes it will work but to use the dsm injectors u need to run resistors
Old May 3, 2003 | 08:36 PM
dfoxengr's Avatar
Default Re: dosnt pull (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">yes it will work but to use the dsm injectors u need to run resistors</TD></TR></TABLE>
which are a big problem?? no...get the box, or 10 ohms at radio shack...
big-cat
May 15, 2006 01:29 PM
Type-X
Feb 7, 2005 11:00 AM
boostedlude3g
May 26, 2004 01:43 AM
BoostedD15B7
Sep 26, 2002 01:15 PM
Drag III Integra
Jan 26, 2002 10:13 AM
