Best block to boost?
Old May 2, 2003 | 09:47 AM
bluebullet's Avatar
Default Best block to boost?
I did a search, but could not find specifics. I want to start a project engine to drop into my 99 civic si in the future. What would be the best choice for a block to start with. I plan to build it up slowly from nothing, basically to learn, and eventually to have a mean engine. Should I look for B18C5, B18 LS block, B18C1, or any other suggestions.
Old May 2, 2003 | 10:03 AM
Spudddy's Avatar
if you do a lsvtec or crvvtec you better build it right, nothing will last unless you build it correctly
Old May 2, 2003 | 10:08 AM
Pengo's Avatar
Default Re: Best block to boost? (bluebullet)
if it's just to learn i'd say just boost watever you got for now to keep it cheap. unless u already have plans for exactly what setup u plan to run, it's really too hard to make such a big decision now. while you may want the block with the most overall potential to build so that u will have alot of room for power to spare later, that would also most likely be a more expensive choice and would suck if u blew it experimenting. good luck
Old May 2, 2003 | 10:12 AM
-iLLuZioN-B18C1's Avatar
i would just go with the b18c1, less hastle of worrying about building it right. if you dont have a good builder, your gonna have issues with the frankenstein motors.
Old May 2, 2003 | 10:13 AM
bluebullet's Avatar
Right now I have my stock b16 that I'm gonna boost, but I want to start building a better engine to swap out later down the road.
Old May 2, 2003 | 10:19 AM
bluebullet's Avatar
I'm seriously considering either a b18 gsr or type R block
Old May 2, 2003 | 10:22 AM
Default Re: (bluebullet)
whats wrong with building the b16? why you wanna swap out the engine? b16 respond to boost very well. if i were you i would just rebuild that block.
Old May 2, 2003 | 06:43 PM
SJP0tato's Avatar
I'm guessing you're probably not going to get a satisfactory answer, just because your question is placing too much credit on people's opinion. What's best to one person could be the worst possible scenario with the next. For example, someone with an extremely tight budget would do well with a stock block and low boost; whereas someone looking to run low 12's would do well with a large displacement decently high revving motor. If you tell us when YOUR idea of "best" is, we could probably give you more concrete answers to your question.
Just my .02,
Ryan P.
Old May 2, 2003 | 10:37 PM
T-sohctec's Avatar
Default Re: Best block to boost? (SJP0tato)
Short & Sweet.
B18C1
Old May 3, 2003 | 03:40 AM
turbopanda's Avatar
Default Re: Best block to boost? (T-sohctec)
I'd have to say the B18C1 GSR block is best for boost.
If you want to jump to something bigger, like a B20B/Z block, then you're gonna have to invest a lot in forged items and a blockguard or new sleeves.
But like any "turbocharged" NA engine, nothing lasts forever. Reliability is all up to the tuner, the engine builder, and your right foot.
B18Sleeper
Jul 22, 2008 05:24 PM
Boostin_GSR
Apr 4, 2007 12:21 AM
Toy Civic
Jan 17, 2007 06:04 PM
tobe1424
Aug 16, 2005 10:11 AM
PROFILES2000
Nov 28, 2001 05:42 AM
