Is this gonna be a problem?
Old Apr 30, 2003 | 04:18 PM
DigitalFusion's Avatar
Default Is this gonna be a problem?
Hey All,
I think I already know the answer, but I will ask anyways since the house doesnt want to come off so I can rotate it... Will having my oil feed and return horizontal (versus vertical) be a problem? Will there be enough oil pressure to just push the oil right thru or am I gonna be risking toasting the bearing?
Old Apr 30, 2003 | 04:28 PM
RenoRacing's Avatar
Default Re: Is this gonna be a problem? (CustomCockpits)
it will be a problem unfortunately.
Old Apr 30, 2003 | 04:30 PM
i kinda figured as much...
Anyone know a good way to get the turbine housing off without beating up the shaft/propeller?
Old Apr 30, 2003 | 04:43 PM
93LSivic's Avatar
Default Re: (CustomCockpits)
Some heat, like a torch....and a big fawkin hammer.
Old Apr 30, 2003 | 05:09 PM
johnisenglish's Avatar
Default Re: (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Some heat, like a torch....and a big fawkin hammer.</TD></TR></TABLE>
Works every time
Old Apr 30, 2003 | 05:11 PM
yeah, kinda afriad to do that tho, there isnt any shaft play on this one, and the turbo over all is in great shape.. Rare too.. its a .63/.60 T3
Old Apr 30, 2003 | 05:42 PM
the bolts all came out fine, but the housing doesnt wanna move... should I use a tourch to heat up the area around where its bolted, then hit it a with a hammer? I am just worried I am gonna kill this thing
Old Apr 30, 2003 | 06:11 PM
Gravy's Avatar
Default Re: (jz)
just be very careful and you should be fine
Old Apr 30, 2003 | 06:39 PM
ghettocrxsi's Avatar
Default Re: (GRTechnologies)
Omg lol.. this is the same exact problem I had.
Same turbo and everything ford air research 60/.63 t3.. good little turbo you have there
Ok what u want to do it put your turbo in a vise by the center section.
Make sure u take all the bolts out of the exhaust housing and then just BEAT THE **** OUT OF IT!@ going around both sides.
It took me and my 300lb 6'8" arab friend about 5 mins of hard hitting! We would hit at the same time on opposite sides of each other.
The heat expands the cast and also the carbon builds up.
Since that turbo is 83-84 so its pretty old. But any ways just beat it till it eventually will fall off, then you can rotate it to where u want
Here are some pics
I first tried that HUGE MONKEY WRENCH!@ didnt work.. thought I was going to break my engine stand. so then I beat it with 2 hammers. and it works
Got it turned to where I wanted straigh down
Modified by ghettocrxsi at 7:51 PM 4/30/2003
Old Apr 30, 2003 | 07:24 PM
great, sounds like fun :/ I'll have to hit it up tomorrow (pun intended)
Old Apr 30, 2003 | 08:43 PM
1.8T_EG's Avatar
OT... customcockpits, can you still do the turbo cartidges for $125?... i tried pming you a while back, but you were mia... anyways... lemme know... and good luck with the turbo...
Old Apr 30, 2003 | 10:27 PM
InfamousRS's Avatar
Default Re: (1.8T_EG)
This post scared me!!! My new SC61 center section came upside down...I didn't think anything of it, just figured I would lossen the 6 bolts and rotated the exhaust hosing until it was in the right position. Then people said you have to heat it up and pound on it with a hammer!!!! I didn't want to pound on my baby...so just for kicks I pulled the 6 bolts out of the ex. housing and the housing came right off no problems... I feel much better now. hehe...just goes to show that all turbos arnt the same
Old Apr 30, 2003 | 10:30 PM
lazerus's Avatar
Default Re: (ghettocrxsi)
LOVE THE PHOTOS LOL!!!!
(this post does not contain more than 1/2 capital letters)
Old Apr 30, 2003 | 10:36 PM
@irborne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettocrxsi &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
nice turbo...is that turbo from a tbird w/ A/R.63 on the turbine? looks just like the one I have here. How does it run on the SOHC. Is that a stock motor?!?!?!
Old May 1, 2003 | 05:47 PM
Default Re: (@irborne)
Its not running quiet yet. Yes its the one from a tbird. I got it from my buddy who put a t3 60-1 on his 2.3l.
There is no way you would need to hit or heat up your new turbo. It has not been heated or had carbon build on it for 10+ years lol. Thats the only reason that I had to hit mine.
I just need some rings for my je's and that motor is done
D16z6 with 8:5.1 je pistons and crower 4340 billet rods.
Acl bearings
Arp headstuds
Str blocksaver block guard
Zex strip/street cam
All OEM Honda gaskets.
Hondata intake manifold gasket
full 3" down pipe no exhaust
and its going into my 90 crx with full obd 1 convert and hondata.
Only thing holding me back is rings and rc 550's or the motor would be getting broken in right now. But also I have to wait for payday tommorow
So I will let u guys know the numbers. Looking for 300+ hp
Old May 1, 2003 | 06:00 PM
zojirushi's Avatar
Default Re: (jz)
man, i had to take a hammer to my slug for about a week.... kept spraying that liquid wrench and hammerin it. finally came off, well worth the struggle.
Old May 1, 2003 | 06:10 PM
Tinker219's Avatar
Default Re: (zojirushi)
KEEP THE BOLTS IN THE TURBO. Just loosen them. I took mine out, and bent the fawking main shaft when I got too crazy w/the hammer. Just some helpful advice.
itr1244
Apr 4, 2007 06:01 PM
GeeGee
Mar 22, 2005 04:14 PM
0 0 0
Oct 26, 2003 08:21 AM
Racer X
Dec 1, 2002 02:34 AM
