Oil Return Line
Old Apr 30, 2003 | 01:20 PM
ntegls's Avatar
Default Oil Return Line
I just bought a -10an return line that is 18inches in length, is this too long or will it work ok, heres what it looks like
http://checkout.verisign.com/c...10765
Old Apr 30, 2003 | 02:07 PM
QCKGSR's Avatar
Default Re: Oil Return Line (ntegls)
depends on where you put it, how you plumb it and stuff
Old Apr 30, 2003 | 04:05 PM
inspyral's Avatar
Default Re: Oil Return Line (QCKGSR)
18" seems kinda long. My drain line is run pretty direct, and it's only about 6" from hose end to hose end. I used two 90 degree swivel seals and Perform-o-flex. I bought like 2 feet, so I have a bunch left over if I ever need to do another drain.
Old Apr 30, 2003 | 04:35 PM
Tomek's Avatar
Default Re: Oil Return Line (inspyral)
thats plenty long.....
Old Apr 30, 2003 | 05:32 PM
ntegls's Avatar
Default Re: Oil Return Line (AztecEJ)
damn, should of got the permoflex
Old Apr 30, 2003 | 06:43 PM
1.8T_EG's Avatar
where did you get the perm-o-flex?
Old May 1, 2003 | 02:50 AM
inspyral's Avatar
Default Re: Oil Return Line (1.8T_EG)
anplumbing.com
Old May 1, 2003 | 04:27 AM
igo4bmx's Avatar
would they sell these items at a hardware store?
i'm in dire need or braided lines and npt parts, and hoping home depot will be my solution
Old May 1, 2003 | 03:10 PM
ntegls's Avatar
Default Re: (igo4bmx)
most likely no
just get from anplumbing
Old May 1, 2003 | 06:26 PM
GOLDBERG's Avatar
Default Re: (ntegls)
http://www.summitracing.com
Old May 1, 2003 | 06:31 PM
Foozball26's Avatar
Default too much
yea 18" is too much, you will probably only use like 6"- 10" of it.
But its better to have more in case you have to re-route or anything
philafelman
Nov 4, 2009 06:21 PM
Sketch_hs
Jun 23, 2005 02:11 PM
DEVIN22CBR
Feb 5, 2004 04:08 PM
degradated
Sep 16, 2001 05:02 PM
