Electronic Load Detector Help!!!!!!!!!
Old Apr 30, 2003 | 03:57 PM
iHave2Cams's Avatar
Default Electronic Load Detector Help!!!!!!!!!
Ok, i swapped a b18b in my 97 civic ex, and it ran good til last friday when my alternator died on me, so i replaced the alternator, and now im getting a ELD code 20 (electronic load detector) and i dont know how to fix it, do you have any ideas?
and the alternator will not charge the battery at all, i charge it with a regular charger and then the car runs but the battery ends up dying
Old Apr 30, 2003 | 04:09 PM
VaporTrail's Avatar
New User
Default Re: Electronic Load Detector Help!!!!!!!!! (iHave2Cams)
your replacement alternator is bad, or the battery is bad. I've seen both cause that problem. Have them both tested
Old Apr 30, 2003 | 04:41 PM
inspyral's Avatar
Default Re: Electronic Load Detector Help!!!!!!!!! (VaporTrail)
Is your speedo acting weird at all? Check the VSS/ALT fuse under the dash. When mine was out, my speedo would be erratic,a nd my alternator wouldn't charge my battery. I went thru 3 batteries and 2 alternators before I found out the problem was a 10c fuse
Old Apr 30, 2003 | 04:46 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Electronic Load Detector Help!!!!!!!!! (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Is your speedo acting weird at all? Check the VSS/ALT fuse under the dash. When mine was out, my speedo would be erratic,a nd my alternator wouldn't charge my battery. I went thru 3 batteries and 2 alternators before I found out the problem was a 10c fuse </TD></TR></TABLE>
Yup, I bet you that is the problem.
Old Apr 30, 2003 | 05:21 PM
iHave2Cams's Avatar
The fuse was out and i fixed it and now my damn fuel pump wont kick on when i turn the key forward.
Old Apr 30, 2003 | 10:50 PM
Arturbo's Avatar
Better than steak
25 Year Member
You see and easy fix. Did you check your fuel pump relay?
art
Old Apr 30, 2003 | 10:57 PM
Trac226's Avatar
Default Re: Electronic Load Detector Help!!!!!!!!! (Arturbo)
My eld came up also when my fuse was burnt. But, my fuse was fried in the first place because my o2 sensor wires were crossed. So, i'd check out your wiring buddy before replacing ure fuel pump or something.
Old May 1, 2003 | 12:17 PM
M.A.R.C.'s Avatar
Default Re: Electronic Load Detector Help!!!!!!!!! (Trac226)
check for ur o2 grounding out on the undercarriage... that was my problem
lmike6453
Jan 16, 2009 06:55 PM
logeywartooth
Sep 14, 2008 07:10 PM
E_F_9
Sep 25, 2007 01:11 PM
z1p
Nov 8, 2004 05:49 AM
EG6[B16A1]
Jun 28, 2003 09:03 AM
