3" downpipe with A/C
Old May 1, 2003 | 10:57 PM
EG6owner-T's Avatar
Default 3" downpipe with A/C
Ok i want this from 94tealGSR who can make custom dp.
I have the revhard kit, he said i can move the intake side of the turbo around to the other side and cut the pipe shorter and hold it with a coupler and thats the way i can still retain my a/c with his custom 3" dp for my bseries in the eg.
I like to know if anyone has done this and got any PICS?
Thanks for your time.
Old May 1, 2003 | 11:02 PM
TEAMGENDAI's Avatar
Default Re: 3" downpipe with A/C (EG6owner)
i almost pretty sure you cannot run a 3 inch down pipe with ac with the stage 2 kit the bend is really tight and might hit, melt the fan if you flip the turbo around it will hit the ac on the intake side of the turbo.
Old May 1, 2003 | 11:05 PM
TurboDANDEE's Avatar
Default Re: 3" downpipe with A/C (TEAMGENDAI)
ya i dont think it will work, u might have a chance if u use a turbo with a 4 bolt DP flange
Old May 1, 2003 | 11:15 PM
EG6owner-T's Avatar
Default Re: 3" downpipe with A/C (TurboDANDEE)
thanks for the replies
(9:08 AM 5/1/2003) TurboDC4: I doubt it would retain the ac with a 3 inch unless you turned the turbo around. I could make a downpipe like that though so let m eknow!
(10:11 AM 5/1/2003) EG6owner: would there be room if you turn the turbo around? since the intercooler pipin has to go up there? got any pics, thanks. for your downpipes are they the same length as the b series header? so the flange would match up etc.
(11:01 AM 5/1/2003) TurboDC4: i have no pics, but there would be room yes. It is also as long as the b series header5.
(11:03 AM 5/1/2003) EG6owner: i have the revhard intercooler kit, im guessin i cut it shorter then weld it, you know if anyone else did this so I can actually confirm and maybe get some pics, thanks.
(11:05 AM 5/1/2003) TurboDC4: i can send you a coupling so that you just cut and clamp. Many people have done this on the board. Ask around. Ill see what i can find.
770_dc2
Oct 22, 2010 05:46 PM
DC-4-Drew
Apr 5, 2008 04:53 PM
AdvanTech
Oct 29, 2004 06:39 AM
hackish
Apr 27, 2004 08:09 AM
