Which FPR for Turbo Setup
Old May 1, 2003 | 03:52 AM
Kutsuju_SLeePER's Avatar
Default Which FPR for Turbo Setup
Plan on throwing in the Revhard Stage 2c Kit on either this week or next. I was gonna run the Stock FPR till i came up on some cash but guess what. Got paid now so im needing one. I been looking into either the AEM or B&M. i did the reasearch but came up with there both pretty good. I thought i could get some more info from u guys. I will only be running around 7 PSI for the time being. Ill ge an STR fuel rail within a month or so. I also read with the B&M, u can drill a small whole so it returns fuel back to the tank, did i read this correctly?
Thanks
Old May 1, 2003 | 11:19 AM
g2turbo's Avatar
Default Re: Which FPR for Turbo Setup (Kutsuju_SLeePER)
i have ran stock in my last 2 setups with no problems. i have heard from a few people that the aem's take a ****. Now i run the s200b, 550's, and stock fpr
Old May 1, 2003 | 11:50 AM
B00STeD's Avatar
aeromotive fpr
Old May 1, 2003 | 12:24 PM
mamaboy's Avatar
your stock is 1:1 ..... but if you want to get an fpr go with aeromotive, sx, or paxton...all the same....
Old May 1, 2003 | 12:50 PM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kutsuju_SLeePER &raquo;</TD></TR><TR><TD CLASS="quote">I also read with the B&M, u can drill a small whole so it returns fuel back to the tank, did i read this correctly?</TD></TR></TABLE>
The hose that connects to the bottom of the FPR is the stock fuel return line. The technique of drilling a relief hole is only meant for people who have a high-output fuel pump that can't get the idle pressure low enough on the B&M FPR. Since supposedly the B&M FPR starts at stock psi and can only add pressure. It can't go below stock and if you have a high-output pump and need to lower pressure, this is the only way. So it depends on your fueling needs and pump if you need to do this or not.
The AEM one supposedly has a wider range of adjustment. It can raise or lower from stock pressure, so you don't need to modify the FPR.
Old May 4, 2003 | 03:31 PM
Default Re: Which FPR for Turbo Setup (XrcR6)
Well i went ahead and got the AEM FPR from options auto salon. I will get the AEROMOTVIE one later on. My friend actaully ordered for me and it was to late to change my mind
Old May 4, 2003 | 10:29 PM
1.8T_EG's Avatar
Default Re: Which FPR for Turbo Setup (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">your stock is 1:1 ..... but if you want to get an fpr go with aeromotive, sx, or paxton...all the same....</TD></TR></TABLE>
best/cheapest place to find one of these fpr's?... thanks...
2kdrift
Apr 10, 2013 12:16 AM
schock3
23
Aug 13, 2009 09:45 AM
boostfed-r
Apr 16, 2008 11:43 AM
Project_EK
Jul 3, 2007 12:21 PM
DvD3
Nov 22, 2005 09:55 PM
