VAFC hack running rich
Old May 2, 2003 | 01:55 PM
DC2's Avatar
DC2
25 Year Member
Default VAFC hack running rich
I'm running a '96 turbo GS-R and recently threw out the Vortech FMU/Bosch pump combination for 450cc '93 Injectors (cleaned and blueprinted by RC)/resistor box/stock pump. I did this a week ago and was only running on one o2 sensor (aft of the cat) and an open downpipe because I need to replace the bottom part due to it rubbing the oil pan after bottoming out. Now that the downpipe is connected, I reconnected the primary o2 sensor and now my car is bogging all over the powerband. My settings are:
1-4k rpm - 38% wide and narrow
4-8k rpm - 37% wide and narrow
I haven't thrown any codes at all (other than the primary o2 being connected) and would like some insight from you guys. I am also running 44psi on the fuel at idle and topping out at 55psi at WOT. Although the primary o2 is a suspect, I'd also want to know if there's any other areas I could look into.
Thanks in advance.
Old May 2, 2003 | 02:17 PM
15psi of fun's Avatar
Default Re: VAFC hack running rich (DC2)
I think your setting are to high try this or go here http://www.thedropshop.com/vafc.htm
1-4k= -40%
4.5k= -38%
5k= -36%
5.5-7k= -35%
Old May 2, 2003 | 02:32 PM
Smashback's Avatar
Default Re: VAFC hack running rich (EFrollingout)
Actually you'll probably end up with -45% or so up to boost and then after that it just depends. Even after Vaportrail tuned mine to a perfect 12:1 it was still a little rich.
Old May 2, 2003 | 04:06 PM
DC2's Avatar
DC2
25 Year Member
Default Re: VAFC hack running rich (PseudoSilvia)
I've now trimmed the fuel to:
1-3k rpm - 46%
and
4k rpm - 45%
All increasing 1k rpms thereafter I'd enrichen by 1% (7-8k rpm it's at 41%)
The bogging has been reduced and it still feels sluggish in the top end. I did compare my settings to everyone elses here and it seems I have to trim back much more than most people. I hope I didn't lean it out too much.
Thanks for the replies.
Old May 2, 2003 | 04:15 PM
Mr.DC2TurBo's Avatar
make sure you have the right pressure sensor. for hondas are 06, not 01. that makes a big difference.
Old May 2, 2003 | 04:16 PM
DC2's Avatar
DC2
25 Year Member
Default Re: VAFC hack running rich (Mr.JDM_KiD)
Yeah I'm okay with that.
It's been 06-In 06-Out ever since I dialed it in.
B18C1CYA
Jun 24, 2003 09:31 AM
matt0199
Sep 4, 2002 10:15 AM
Mr. Softee
Jul 6, 2002 08:47 PM
dbman96
Feb 24, 2002 09:02 AM
liam821
Feb 8, 2002 11:31 AM
