?'s about this guys posts
Old May 1, 2003 | 01:34 PM
drumking15's Avatar
Default ?'s about this guys posts
Is this the right logic?
Ok so i was running some thoughts through my head, and I am not sure if this has been covered but maybe someone can shed some light. I’ve been thinking a lot about what compression ratio to run when i build my motor.
OK i know not all my numbers might be right or the calculations but bare with me you will get the idea
So say I did 8.5:1 and ran 11 psi of boost,
11 + 14.5(atmospheric pressure roughly) * 8.5 = cylinder pressure of 216.75
Now if i up the compression ratio to say 10 and try to get the same cylinder pressure
216.75( cylinder pressure) / 10 = 21.675 - 14.5 = 7.175 psi
so what my calculations say is that at 8.5:1 at 11 psi i get a cylinder pressure of 216.75 and if i up my compression ratio to 10 and try to reach the same cylinder pressure i would only have to run 7.2 psi
SO i guess what my question: Just because the calculations say that i will have equal cylinder pressure by adjusting the boost after i change the compression ratio, does this mean i will make more or less or the same power?
i know some of my cylinder pressure numbers might be off because im not sure how to take in to account for the dome of the head, but you get the idea of my question
Old May 1, 2003 | 01:36 PM
boosted hybrid's Avatar
Default Re: ?'s about this guys posts (drumking15)
Boost and compression go hand in hand in terms of overall cylinder pressure. In most cases its better to let the turbocharger make the power, in the case of lower compression and more boost pressure. You'll make equal amounts of power, but you'll make different levels of torque at the same power levels. This is due to the nature of higher compression and boost.
Old May 1, 2003 | 02:40 PM
drumking15's Avatar
So what would be a good balance? Im posting this for my freind and he evetaully wants to go w/ higjer boost levels in his h22...He plans on starting on rather low levels of 7-10psi but then pushing close to 20ish...I recomended him 9.0 or 9.5cr becuase when he is not making boost he still needs some "n/a power" and the lower cr he goes the less it has to get him going. Thanks any more input is helpful!
markopolo
Mar 5, 2017 06:16 AM
lke2drvgsr
Jan 11, 2004 10:02 AM
prelittlelude
May 2, 2003 07:12 AM
echo999
Mar 6, 2003 10:31 AM
Ragezero76
May 15, 2002 04:17 PM
