3" DP with 5 bolt turbonetics flange...possible?
just looking at it and my 2.5 is pretty close to the nuts.. i would think i would run allen headed bolts insead of studs.. would 3" dp fit?
1 Post
Re: 3" DP with 5 bolt turbonetics flange...possible? (BoostedH23a1)
on my AC manifolds, i just eliminate one of the bolts. still seals great if you use mega-copper silicon or something in-between everything.
Re: 3" DP with 5 bolt turbonetics flange...possible? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">on my AC manifolds, i just eliminate one of the bolts. still seals great if you use mega-copper silicon or something in-between everything.</TD></TR></TABLE>
thats a bad idea, it'll leak sooner or later.
1 Post
Re: 3" DP with 5 bolt turbonetics flange...possible? (t04s)
hmm...havent had any problems yet. if you have some small leaks after the turbo, it doesnt matter THAT much. you might register running a little leaner because of some added 02 in the system, but not enough to make a real difference.
plus, my o2 sensors are about 3 inches away from the turbo, so they get a pretty direct reading...
Kinda hard to see, but like this:
Re: 3" DP with 5 bolt turbonetics flange...possible? (hybridvteceg)
check out http://www.cheapturbo.com they have a nice 5 bolt/ vband thing. would be nicer and easier to work with, also fit the 3 inch dp with no prob
_Cyclone_
10
05-16-2005 01:15 PM
project dc2
05-15-2004 03:19 PM
