SOHC w/boost, what rpm you go to?
Old 05-02-2003, 09:08 AM
94dxt's Avatar
Default SOHC w/boost, what rpm you go to?
what rpm you all are taking your boosted sohc to and your setup?
Old 05-02-2003, 09:48 AM
turbo sol's Avatar
Default Re: SOHC w/boost, what rpm you go to? (94dxt)
stock 7200 rev limit
Old 05-02-2003, 10:12 AM
gitwidit's Avatar
Default Re: SOHC w/boost, what rpm you go to? (turbo sol)
At the track I'll spin it to 8.5k (balanced)
turbod16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">stock 7200 rev limit</TD></TR></TABLE>
same here..
Old 05-02-2003, 10:47 AM
RyanEJ8's Avatar
Don't go past the stock 7200 until you upgrade valvetrain.
Edit: I see in your sig now. Spin up to 8k at least, if you got a cam to handle it.
Old 05-02-2003, 12:38 PM
inspyral's Avatar
Default Re: SOHC w/boost, what rpm you go to? (RyanCivic2000)
What cam will make power that high in the rev range?
Old 05-02-2003, 08:11 PM
RyanEJ8's Avatar
Default Re: SOHC w/boost, what rpm you go to? (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">What cam will make power that high in the rev range?</TD></TR></TABLE>
Haven't looked into it that much yet, but I think Crower Stage 3 would be one.
Old 05-02-2003, 08:14 PM
Trial User's Avatar
I have a Gude turbo spec cam and it seems to still be building massive amounts of power even at redline. I need to get rid of that pesky redline.
Old 05-02-2003, 08:17 PM
RyanEJ8's Avatar
Default Re: SOHC w/boost, what rpm you go to? (Trial User)
Get a Hondata.
Old 05-02-2003, 08:22 PM
boosted hybrid's Avatar
With the .63a/r that i am using for my project z6 the redline will be 8200rpm. The valvetrain is upgraded to handle the higher redline, as well as balancing the reciprocating mass to damper out oscillations. Pick your redline based upon your exhaust housing size if you are geared more for street driving, or pick your redline based upon your desired trap speeds if you are geared more for 1/4 mile. The .48a/r housing the 7200 redline is the best choice, the since the 7000 rpm range is where the exhaust housing will limit peak power output. The .63a/r the redline is 8000rpm, and the .82a/r rpm the redline is 9000rpm.
Old 05-02-2003, 08:37 PM
5thgencivic's Avatar
7200. Guys, what does your tach read at limiter? My stocker reads like 7500....
Old 05-02-2003, 09:18 PM
Daniel's Avatar
Yep, same w/ me.
Old 05-02-2003, 11:42 PM
swrdply400mrelay's Avatar
Default Re: SOHC w/boost, what rpm you go to? (Daniel)
I used to rev to 8k using an Si (B16A2) ECU.
mercutio_07
02-03-2008 10:55 AM
Volcom
09-10-2007 10:06 AM
whitemike1644
26
04-01-2004 08:50 PM
oldskooljdm
10-22-2003 08:18 AM
GapxGuy
08-04-2002 09:15 AM
Quick Reply: SOHC w/boost, what rpm you go to?
