Need a little help here ASAP!!!!!
Old May 3, 2003 | 08:44 AM
coyote's Avatar
Default Need a little help here ASAP!!!!!
ok i found this turbo it's a T3/T4 for 399+ shipping. is this a good deal it seems it but ya never know so here are the spec's on it and tell me what you think. this will be going on a CRX SI with a B16 i plan to boost around 10psi id that helps thank guys ....
BRAND NEW TURBO
T04E TURBOCHARGER
3" INLET DIAMETER
2" OUTLET
WET FLOATING BALL BEARINGS
1/8 NPT OIL INLET
3/8 NPT COOLANT
T3 / T4 FOOTPRINT OK !!
SPECS:
.57 COMPRESSOR WHEEL TRIM
.60 A/R COMPRESSOR
.63 A/R TURBINE
THIS TURBO CAN EASILY DO 25 psi
530 whp ON B SERIES SWAPS
Standard T3 Flange,
Old May 3, 2003 | 09:00 AM
DaveF's Avatar
Default Re: Need a little help here ASAP!!!!! (coyote)
the wheels might possibly be a slight bit large for a b16 @ 10 psi, but if you do a build up in the future why not get it. only other concern is "wet floating ball bearings"
i am assuming that its a water cooled turbo??
Old May 3, 2003 | 09:05 AM
93LSivic's Avatar
SOnds pretty good. Its just a 57 trim .63 turbine t3/t4e. The wet bearings sounds weird to me also, i think it just states its oil cooled.
I would also ask if it has the 360 degree thrust washer, its important. If it doesnt then its a very generic t3t4 and i would spend the extra cheese to get it.
Old May 3, 2003 | 09:08 AM
coyote's Avatar
Default Re: Need a little help here ASAP!!!!! (2.2Lcivic)
i don't know about the wet bearings .most likely i will not be doing a build up i just want a fun street car that will onlt see track time maybe once or twice a year if that . will this have a lot of laag ?
Old May 3, 2003 | 10:11 AM
coyote's Avatar
bump
Old May 3, 2003 | 02:21 PM
coyote's Avatar
ttt
Old May 3, 2003 | 02:24 PM
ninesecrx's Avatar
it will be a tad laggy for your car. Id go a tad smaller if the goal is 10 pounds and to keep it solely as a fun street car.
Old May 3, 2003 | 03:03 PM
coyote's Avatar
Default Re: Need a little help here ASAP!!!!! (ninesecrx)
what would be a good size then ? i see a lot of saab turbo with a 42/48 trim would that be better ?
Old May 3, 2003 | 03:47 PM
coyote's Avatar
bump
Old May 3, 2003 | 04:19 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">it will be a tad laggy for your car. Id go a tad smaller if the goal is 10 pounds and to keep it solely as a fun street car.</TD></TR></TABLE>
i agree
get a t3/to4e, but maybe like a .58 or .48 a/r ratio
Old May 5, 2003 | 02:44 PM
coyote's Avatar
like a saab turbo or is that too small for a B16?
Old May 6, 2003 | 04:10 PM
coyote's Avatar
bump
Old May 6, 2003 | 05:46 PM
coyote's Avatar
bump for the night team
sdracerboy
Jun 18, 2008 09:33 PM
og_hatch_90
Jan 12, 2006 01:24 PM
acuracy r
Feb 21, 2005 10:36 PM
jfoster
Apr 14, 2004 09:05 PM
delslow94
Jul 29, 2003 02:50 PM
