drag and deltagate
Old May 2, 2003 | 01:03 PM
InTeGrA B18b1's Avatar
Default drag and deltagate
IM gonna put the drag manifold, OPEN dp with a deltagate @ 7psi. How high you think its gonna spike? would a tial wg do the same with a open downpipe?
Old May 2, 2003 | 01:14 PM
Default Re: drag and deltagate (InTeGrA B18b1)
if i ran 2.5 inch exhaust would it prevent creep? i already know that 3 will make it creep
Old May 2, 2003 | 02:29 PM
15psi of fun's Avatar
i would like to know to im about to do the same thing
Old May 2, 2003 | 02:43 PM
TeStUdO's Avatar
i run a 3" open downpipe. i got crrep w/ the deltagate. i switched to the tial still got creep with the drag mani. bought a MBC and it fixed it
Old May 2, 2003 | 02:46 PM
psi420's Avatar
I run the Drag kit, and 2.5" exhaust
when i run open downpipe, on the 7psi spring, my boost shoots up to about 12-13psi
I only did it twice, and I will never do it again.
Old May 2, 2003 | 02:50 PM
Default Re: (psi420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">I run the Drag kit, and 2.5" exhaust
I only did it twice, and I will never do it again.</TD></TR></TABLE>
so how did u fix it the problem&gt;?
Old May 2, 2003 | 03:01 PM
psi420's Avatar
Default Re: (InTeGrA B18b1)
Put the rest of my exhaust on with a muffler.
Holds perfectly steady at 8psi now.
Old May 2, 2003 | 03:03 PM
Flamenco-T's Avatar
the problem is mainly on the drag manifold, the WG placement on it, is the reason why it spike.
solutions, get tial, get a steady BC, like manual or profec B
and if you wanna go a lil further, port match the opening on the manifold and the WG opening, if they are not equally the same diameter
stan
Old May 2, 2003 | 09:12 PM
Default Re: (Flamenco-T)
so lets say i just get the piping ran to my stock exhaust with a muffler. will i creep? i know i will loose some power but wouldn't it be way safer than open dp?
Old May 3, 2003 | 12:50 PM
TeStUdO's Avatar
it probably wouldnt creep as much as an open dp, but your turbo wont spool for **** with the stock exhaust. probably alot safer that open Dp though
ella94
Jul 7, 2006 05:37 PM
94B18B1Teg
Apr 25, 2005 05:50 PM
b00sted4dr
Nov 15, 2004 09:25 AM
11psiTurboSI
May 6, 2004 08:21 AM
Rory Breaker
Jan 12, 2004 03:08 PM
