why is my profec B doing this?
Old May 1, 2003 | 08:48 PM
SpoolnG2's Avatar
Default why is my profec B doing this?
i bought a profec B a little while ago. (i have a 9lb spring in my tial wastegate) when i first got it, on the low boost setting i only had to turn the **** like a little before half and it went to 10psi. now i have to turn it to almost 3quarters to get 10psi. i checked the hoses and their all hooked up with no leaks. did a boost test, and i'm not leaking boost from anywhere. whats the deal?? can anyone help me?
Old May 1, 2003 | 09:35 PM
MiraiZ's Avatar
Default Re: why is my profec B doing this? (SpoolnG2)
where is your balance **** set to?
Old May 1, 2003 | 09:43 PM
SpoolnG2's Avatar
Default Re: why is my profec B doing this? (MiraiZ)
the middle, but no matter which way i turn it, it still does the same thing
Old May 1, 2003 | 09:52 PM
TurboDANDEE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">the low boost setting i only had to turn the **** like a little before half and it went to 10psi. now i have to turn it to almost 3quarters to get 10psi. ?</TD></TR></TABLE>
Im having the same problem with high boost, i cant seem to pass up 17 psi.
Old May 1, 2003 | 10:02 PM
SpoolnG2's Avatar
Default Re: why is my profec B doing this? (TurboDANDEE)
i called greddy, and they told me it changes b/c of the atmostpheric pressure. i can't change that much for no reason.
Old May 1, 2003 | 10:41 PM
so atmospheric pressure changes the boost pressure in the manifold? huh, can u explain a little more?
Old May 1, 2003 | 10:50 PM
MiraiZ's Avatar
That is an odd answer...i don't think the pressure in the intake manifold is relative to the pressure outside.....so according to Greddy, my boost guage should go up just my driving up in the mountains...um...don't think so!
I think its gotta do with either the vac lines somewhere or the black box. My boost ALWAYS spiked until I got my car back from the rebuild. They did redo my vac lines and added more ties to vac nipples and now its right on all the time. I saw recheck EVERYTHING again...and try turning the balance know up all the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE &raquo;</TD></TR><TR><TD CLASS="quote">so atmospheric pressure changes the boost pressure in the manifold? huh, can u explain a little more?</TD></TR></TABLE>
Old May 1, 2003 | 10:54 PM
ya, i thought it was kind of an odd answer too.. didnt make sense to me.
Old May 1, 2003 | 10:56 PM
TEAMGENDAI's Avatar
i think there are dip switches in back of the profec i for got the setting bu ti know if you change the switches there is a plus or minus some value sorry for not to clear but just a little direction.
Old May 1, 2003 | 11:00 PM
Default Re: why is my profec B doing this? (TEAMGENDAI)
ya there's 4 switches on the back and i dont know what the **** they do. i just put it on the way the greddy manual told me to set it for, External Wastegate.
Old May 1, 2003 | 11:03 PM
TEAMGENDAI's Avatar
i think there are 2 external waste gate settings.
Old May 1, 2003 | 11:12 PM
hhhmmmm, i'm gonna have to look into that
http://greddy.com/Technical/profec_frame.htm
Old May 2, 2003 | 08:49 AM
RedHB's Avatar
Im having the same problem with high boost, i cant seem to pass up 17 psi. </TD></TR></TABLE>
Do you have a 6psi spring in there or something? If you want to boost higher than 17psi, try starting off with a higher spring like a 9psi one.
Old May 2, 2003 | 10:47 AM
12 lb. spring
Old May 2, 2003 | 12:08 PM
Default Re: (TurboDANDEE)
OK im retarded
i had mine set on the actuator type (when overboost occurs) all along I wonder how much of a difference this will make?
br1ev8
Apr 6, 2006 02:44 PM
musclefella
Mar 26, 2006 06:21 PM
01geeser
Nov 22, 2002 02:29 AM
