Maxrev BOV is garbage
Old May 2, 2003 | 10:05 AM
Canuk_SiR's Avatar
Default Maxrev BOV is garbage
I started up my car today, and surprisingly it fired up on the first try (aem ems with 450cc's, with the maxrev turbo kit.) but I had a problem bringing my idle down. I tried everything I could with teh aem, but nothing brought it below 2200. I thought maybe I had a leak between my injectors, 'cause when I wore away some of the rubber bushing, I thought I put a gap netween the injector & grommet, but that checked out, everything was sealed up there. I then thought that maybe it was the bov, cause it does lack a diaphragm, and guess what, that's the prob. I took off the vac. line and plugged it, and the revs were somewhat normal (ecu still needs to be tuned) at idle.
I don't understand how that bov could go to the market like that. Does anyone out there have this valve working? I can't see anyone having a good maxrev valve, if its built like this. I can't wait til I get my HKS bov.
Old May 2, 2003 | 10:49 AM
Smashback's Avatar
Default Re: Maxrev BOV is garbage (Canuk_SiR)
I've never heard of probs with it. Your description of the problem is hard to understand, but I think I get the idea. Did you adjust the tension?
Old May 2, 2003 | 10:57 AM
Scott - 93HB Si's Avatar
Andy,
The BOV sits infront of the TB.....how does it affect Idle??
Old May 2, 2003 | 11:08 AM
skhonda's Avatar
Hrm... not really following exactly what's wrong.. mine works perfectly
Old May 2, 2003 | 11:11 AM
metal-x's Avatar
Default Re: Maxrev BOV is garbage (skhonda)
haha thats why I sold mines
Old May 2, 2003 | 11:16 AM
BoostedsiR's Avatar
Default Re: Maxrev BOV is garbage (metal-x)
minem works and I was bitching about it but it just aint loud I want something that sounds massive not this little **** and I told them at maxrev that I want a new one but there has been no word on that yet the kit is great besides the bov and diy is kind of annoying
Old May 2, 2003 | 12:18 PM
Rain_man's Avatar
New User
Default Re: Maxrev BOV is garbage (Scott - 93HB Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott - 93HB Si &raquo;</TD></TR><TR><TD CLASS="quote">Andy,
The bov is actuated by a vacuum line off the intake manifold. I guess the bov wasn't sealing the vacuum line properly and he was getting a leak there.
Old May 2, 2003 | 12:28 PM
Default Re: Maxrev BOV is garbage (Rain_man)
That would make sense......
I remember the time i forgot to connect my PCV to the IM......yup, you get major idle problems!
Old May 2, 2003 | 01:05 PM
Canuk_SiR's Avatar
ya, that's the problem. The bov doesen't seal the mani from the atmosphere. I can connect a tube from the bov and easily suck in air with my mouth through the bov.
Idle isn't really a problem, it just revs higher then normal. Its actually steadier with the leak then it is with the ems alone!
Old May 2, 2003 | 01:43 PM
SiRkid's Avatar
use it as a paper weight and get somethign else already
boosted_duece
Nov 23, 2005 09:29 PM
CRXdan
Dec 11, 2004 10:38 PM
Blanket Jackson
Nov 28, 2004 12:18 PM
TheIntegraGuy
Dec 2, 2002 11:32 AM
skrewdlude
Jul 11, 2002 10:08 PM
