Oil return location on 4 bolt t3/t4
I was doing a test run through of all my parts, just fitting everything together the other night to make sure all the parts piece together properly. Then i noticed, my oil return is facing the same direction as the exhaust inlet.
Now, from my limited knowledge, the return is a gravitational return to the oil pan, something's wrong here.... or am i just a noob and this is normal? (first turbo project so its possible im just a n00b )
here's a pic, don't mind the ghetto polish
there's the return
there's the feed, on the opposite side.
-Ryan
there's the return
-Ryan
Re: Oil return location on 4 bolt t3/t4 (tegasaurus)
Just loosen the bolts around the center section, and spin it to your desired position, and tighten it back up.
Re: Oil return location on 4 bolt t3/t4 (youngkow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow »</TD></TR><TR><TD CLASS="quote">Just loosen the bolts around the center section, and spin it to your desired position, and tighten it back up. </TD></TR></TABLE>
yup! its called clocking the turbo. Make sure you dont miss any when re-tightening them.
Re: Oil return location on 4 bolt t3/t4 (B18EG6)
k, cool... is there any torque specs that i should follow or just tighten the bastards real tight?
-Ryan
-Ryan
NeXtLeVeL_TyPe_R
04-15-2002 10:07 PM
