Anyone running a stock b20b w/ turbo??
Thinking about doing this. What do you guys think? I want to pick up a jdm b20b with low miles and maybe boost like around 10 pounds for daily driving. Will this motor hold up?? Let me know!
Re: Anyone running a stock b20b w/ turbo?? (arsenaldragster)
i'm running a b20z wich has a little more compression on a stock ecu and fmu setup and i'm running 8lbs no prob.......it's only been running a week so far but i've been pretty hard on it......
Re: Anyone running a stock b20b w/ turbo?? (TwistedHatch)
I am running a stock B202B with 8psi. It isn't tuned, but does run pretty rich up top. I have an FMU set up with 310's. Don't expect much power up top.
my friend has a b20b stock bottom end with a built(ported, polished, cams, spring, retainers) ls head and is running about 8+ psi on it and he's having no problems and all of this is after about 10 bottles of nitrous on a 100 shot.
Re: Anyone running a stock b20b w/ turbo?? (HavokRacing)
if you have injectors and good stand alone managment you should be able to hold 12-14 easy tuned properly on a decent condition motor...
Re: Anyone running a stock b20b w/ turbo?? (b20turboic)
the walls are thin yes but if spark is tuned and fuel is there then the walls shouldnt be an issue unless its ghetto tuned or your motor is beat
