are stainless steel lines necessary for the oil return?
Re: are stainless steel lines necessary for the oil return? (metal-x)
it's not 100% necessary, but the return line on a lot of turbo kits/setups out there run really close to the downpipe, and the heat from the downpipe tends to melt the rubber hose.
Re: are stainless steel lines necessary for the oil return? (igo4bmx)
after running 3weeks with the rubber return line it developed a crack. Play it safe with the braided lines.
you take the chance of the rubber line exploding due to the heat that is around like the downpipe, so spend a little extra money and be safe.
vladd
08-19-2006 06:39 PM
reignofchaos
07-27-2003 10:34 AM
