gsr cams better for boost?
Old Oct 26, 2003 | 08:19 AM
shotty527's Avatar
Default gsr cams better for boost?
i ahve b16 and heard that gsr cams are better for boost? is this true and will they fit into my head without a lot of trouble?
f/s drag gen 3 manifold w/ wastegate - asking 360 or b/o
Old Oct 26, 2003 | 08:38 AM
FredoSP's Avatar
Default Re: gsr cams better for boost? (shotty527)
First, if your selling things post it in the Classifieds FI room.
About the cams, yes they will fit, you will need cam gears if you want to tune them. The GSR cams have a higher lift and longer duration then the B16 cams.
Old Oct 26, 2003 | 11:31 AM
shotty527's Avatar
Default Re: gsr cams better for boost? (FredoSP)
if i just put cams in there would be no difference ? i am trying to keep most stockinternals, would gsr cams work? would i need a knew timing belt?
wearyfurball
16
Feb 19, 2008 08:54 AM
99B16Si
Apr 10, 2006 04:28 AM
Slow_import
Oct 12, 2005 02:01 PM
91b16civic
May 13, 2003 04:26 AM
