Any hondas here running Haltech
Old Oct 29, 2003 | 10:10 AM
30psi Teg's Avatar
Default Any hondas here running Haltech
I wanted to see if anyone out there was running a haltech system on their honda because I have a few questions with my ignition set up.
Whats happening is I think my ignition is advancing to far as the revs go up I am gonna say probably in the neighbor hood of like 30-40 deg. underboost.
Old Oct 29, 2003 | 05:23 PM
speedworks's Avatar
Default Re: Any hondas here running Haltech (30psi Teg)
do a datalog to see what the timing is doing
Old Oct 29, 2003 | 07:19 PM
done's Avatar
ill be running the e6x in a month.
Old Oct 29, 2003 | 09:09 PM
saso
Guest
Posts: n/a
Default Re: Any hondas here running Haltech (Jordo)
Haltech here e6k modified.
Old Oct 29, 2003 | 09:10 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Any hondas here running Haltech (saso)
Talk to EFIGUY..
art
Old Oct 29, 2003 | 09:16 PM
austrian type-R's Avatar
Default Re: Any hondas here running Haltech (Arturbo)
I run a e6k too.
Old Oct 29, 2003 | 09:46 PM
Killer_B's Avatar
Does the E6k need to be re-tuned if the temp changes within 20 degrees ?
Old Oct 29, 2003 | 09:51 PM
Default Re: (Killer_B)
What do you mean exactly. You tune it and you can drive it in all weather and temp situation......you have to finetune the cold start up choke programm, cause it is hard to tune it at one time, cause the engine heats up quick, so you have to programm the start up map a few times.
Old Oct 29, 2003 | 10:03 PM
Killer_B's Avatar
here in Ny during the summer the average temp is 80 degrees. in the winter it's about 30 degress.
if the car is tuned during the summer, will it have to be re-tuned during the winter?
Old Oct 29, 2003 | 10:13 PM
no, normaly the programmer-guy has the knowledge how to tune the map for colder temps. If the car does not start good, you should richen up the mixture in the collant map, maybe play a bit with the timing.
Old Oct 29, 2003 | 11:53 PM
swlabhot's Avatar
Default Re: (austrian type-R)
Is it easy to use and tune compared to other ECUs?
Old Oct 30, 2003 | 12:26 AM
Default Re: (swlabhot)
yes, that is what people telling me. I have never used an other ECU, but it is easy to use and simple DOS programm
Old Oct 30, 2003 | 04:04 AM
Jared's Avatar
if your ignition map is correct, but you have the distributor reluctors wired backwards, the timing will change as the rpms increase.
Old Oct 30, 2003 | 05:18 AM
30psi Teg's Avatar
Well I cant really datalog cause the car melted the rings on cyl. 1 & 2 but I was watching the haltech data page during the dyno run and it just has it going to 15 deg. what I have it set for. but I think it was going a lot further because of a previous test that I ran.
Old Oct 30, 2003 | 05:20 AM
30psi Teg's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">if your ignition map is correct, but you have the distributor reluctors wired backwards, the timing will change as the rpms increase.</TD></TR></TABLE>
Holy **** I think that may be it. Because I could find anyone who knew how to wire up the non-obd dist.
Thanks man
Old Oct 30, 2003 | 09:43 AM
Jared's Avatar
Default Re: (30psi Teg)
i never thought it was possible because a reluctor is just an electromagnet so to speak, but there is a + and - on a reluctor.
Old Oct 30, 2003 | 10:11 AM
30psi Teg's Avatar
Default Re: (Jared)
exactly the same thought I had. And since I couldnt find anyone who had done a non-obd dizzy I just mad an educated guess. Dont think Ill do that again lol.
Old Oct 30, 2003 | 12:22 PM
spooler's Avatar
I use a E6K on my Miata.
This may help you out.
http://www.k2rd.com/haltech/drawings/T04.pdf
blackeg
Engine Management and Tuning
17
Dec 1, 2014 04:53 PM
krayzieboi213
May 27, 2008 09:46 PM
jdmturbo1127
May 8, 2007 09:13 PM
whitecrx
Mar 6, 2005 05:51 PM
7rrivera7
Jan 16, 2003 01:51 PM
