What do I need?
Old Oct 27, 2003 | 09:52 AM
slamdunkcivic's Avatar
Default What do I need?
I have a B16A and want a turbo set up, I know I need a turbo, manifold, charge pipes and intercooler. The whole engine management confuses me, how much is hondata to buy/tune? Any other options?
I also have a spare B16A2 block that needs rebore and rings, what should I do to make it able to take proper boost reliably? This will be later on. Boost my stock B16A now and hopefully build up the other bottom end for later.
Thanks in advance (for being flamed too!)
Old Oct 27, 2003 | 10:02 AM
Trak_Day's Avatar
New User
You gotta be more specific and people will definately be willing to help. For example what are your goals? Daily driver? hondata is about 450 with boost...just give us a bit more info and i will be happy to help you out
Old Oct 27, 2003 | 01:19 PM
Its a daily driver, odd evening and weekend at the track. Ideally like to do 14 - 14.5 1/4 to keep up with my buddys ZC powered 85-87 civic!
It needs to be reliable, as in give it a hard time and be able to drive home!
Would supercharging be better? Does that need engine management as well?
Old Oct 27, 2003 | 01:25 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: What do I need? (slamdunkcivic)
Your best bet is at the top right hand corner of your screen ^
Old Oct 27, 2003 | 01:47 PM
.ShawnD.'s Avatar
things that are a must to have
turbo
manifold
down pipe
ic/pipes
welded in oil return line thing
misc. vacume lines
some kinda boost control
BOV
look in to wastgate options
things to look into
engine management (hondata,AEM ems) ect
bigger injectors (310-450)
turbo timer
bigger exhaust
boost guage
14 psi on a stock b16 is a lot but with the right tunning im sure its possible
i know the hondata was 100.00 an hour to tune on the dyno and was well worth the almost 70 extra HP it made!! def spend the money on a good engine management system!! and find the right person for the job
im sure i left some stuff out but this was quick
eagles3
May 29, 2008 12:50 PM
B16CRXT
Sep 8, 2004 08:22 PM
es four
Mar 31, 2003 03:38 PM
JohnysZC
Feb 27, 2003 10:13 AM
97itr86
Nov 25, 2002 11:01 AM
