Wastegate Question
Old Oct 28, 2003 | 06:23 PM
Taikonaut's Avatar
Default Wastegate Question
Alright so I just got my wastegate and the only one they had at the shop was a .45bar (6.5psi) one. My question is what exactly does the spring pressure do?
Old Oct 28, 2003 | 06:40 PM
Ricey McRicerton's Avatar
Default Re: Wastegate Question (Taikonaut)
Controls how much boost the wastegate will hold before it opens. Stiffer springs can hold more boost. With the spring you have now, you won't be able to boost over 6.5 psi.
Old Oct 28, 2003 | 06:51 PM
Taikonaut's Avatar
Default Re: Wastegate Question (Ricey McRicerton)
So if I got a 1 bar spring I'd only be able to boost up to 14.5psi?
Ben Huynh's Avatar
If you got a 1bar spring the LOWEST you can boost is 1bar.
Old Oct 28, 2003 | 07:35 PM
Taikonaut's Avatar
Default Re: Wastegate Question (ben@importparts.com)
Ok so what you two just said contradicted each other.
"Controls how much boost the wastegate will hold before it opens. Stiffer springs can hold more boost. With the spring you have now, you won't be able to boost over 6.5 psi." -Ricey McRicerton
"If you got a 1bar spring the LOWEST you can boost is 1bar." -ben@importparts.com
So from what Ben is saying is that if I get a 1 bar spring I mininum I can boost is 1 bar. But from what Ricey is saying the maximum I can boost is 1 bar. So Which one is it?
Old Oct 28, 2003 | 07:37 PM
Maybe I'm wrong (I run on an internal wastegate) but Ben knows his stuff, so talk to him. I always thought that the 1 bar spring would only hold to like 14.7 psi.
Old Oct 28, 2003 | 07:40 PM
AP-Signworks1's Avatar
They're both right. A 6.5psi spring means you should only be able to boost 6.5 psi. No more, no less. Of course this doesn't take into account boost controllers which would allow you to boost higher which is why ben said the lowest you can boost is 1 bar if you had a 1 bar spring.
ie, on my Tial with the 6.5 psi spring, I see 6.5 psi on my setup no more, no less. But if I had a boost controller, I could go to say 12 psi. But I would never be able to go below 6.5 psi. Without the boost controller, I couldn't go over 6.5 psi.
Old Oct 28, 2003 | 07:47 PM
Taikonaut's Avatar
Default Re: Wastegate Question (AP-Signworks1)
Alright makes sense now - thanks guys
Old Oct 28, 2003 | 08:20 PM
Ben Huynh's Avatar
Yea we're both right.
GPoodle
Guest
Posts: n/a
Wait... but the Tials are adjustable too, right? You shouldnt be fixed at 6.5psi.
On my Deltagate, it has a 6 lb spring meaning the minimum I can boost is 6 psi. You can adjust it to like 20 lbs (havent taken it that high).
There are some contradicting posts here.
Old Oct 28, 2003 | 08:21 PM
Ben Huynh's Avatar
Default Re: (GPoodle)
The only adjustable wastegate I know of is the Deltagate.
Old Oct 28, 2003 | 10:00 PM
Tials aren't adjustable. I don't think the spring is swappable. One Deltagates and Racegates, you can swap out springs to adjust boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GPoodle &raquo;</TD></TR><TR><TD CLASS="quote">Wait... but the Tials are adjustable too, right? You shouldnt be fixed at 6.5psi.
There are some contradicting posts here.</TD></TR></TABLE>
Old Oct 29, 2003 | 03:38 AM
Happyman's Avatar
Default Re: (AP-Signworks1)
I thought tial wastegates were swapable? Doesn't matter to me I'm an internally gated fella lol But I thought I read somewhere that you can swap springs in the tial.
Old Oct 29, 2003 | 11:34 AM
Ben Huynh's Avatar
Default Re: (eh6turbo)
You can change out springs in Tial wastegates.
vg7z
Sep 20, 2006 08:27 PM
yusoslo
Jul 12, 2003 08:01 PM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
BoostedSi
Feb 11, 2003 10:08 AM
shingles
Jan 24, 2003 01:58 AM
