Return fitting question
Old Oct 27, 2003 | 06:31 AM
Rory Breaker's Avatar
Default Return fitting question
I have a t3/t04e from a Drag kit, and I will be upgrading the return line to a braided line per everyones recommendation. I have (bear with me here) the braided line, a red/blue swivel fitting on each end like the one pictured in Stans kit here:
..as well as the "flare to pipe" 1st one on the left in this picture:
Will that flare fitting bolt right on to the t3/t04e or will I need something else like an adapter? I also have the fitting in the oil pan obviously. Do I have everything I need?
Old Oct 27, 2003 | 06:36 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Return fitting question (newgsrdriver)
you need an oil retun flange, then everything will bolt up.
Old Oct 27, 2003 | 07:25 AM
Default Re: Return fitting question (HybridcivicLS-T)
Where can I get that?
I was under the impression that I could possibly use the flange on the turbo in the kit, is that not a possibility? The turbo should be here by the end of the week, so I dont have it in front of me to check unfortunately.
Old Oct 27, 2003 | 07:26 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Yeah you should be able to use that flange. Im not completly sure what comes in the kit but It should work.
Old Oct 27, 2003 | 07:30 AM
Awesome. So the male/male fitting that I have that screws into the end of the swivel fitting on the turbo side of the braided line should screw right into the flange as it comes from Drag? (Just clarifying)
Old Oct 27, 2003 | 07:35 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
If i understood yiou correctly yes.
Old Oct 27, 2003 | 05:24 PM
Here are some pictures of exactly what I have:
The blue fitting is a russell fitting, the box says "Adapter #10 Flare x 1/2"NPT"
Now that I posted pictures, do you still think I have everything I need, and I do not need a different flange for the turbo or anything else?
Old Oct 27, 2003 | 05:32 PM
Flamenco-T's Avatar
You just need a drain flange nick..
stan
Old Oct 27, 2003 | 07:12 PM
HXMan's Avatar
I don't remember the part number, but what I did was instead of have the Adaptor #10 flare x 1/2 npt, and the 90 Deg -10 an fitting I found a 45 deg swivel fitting with I believe a 1/2 npt male. It screwed directly to the turbo flange, and allowed me to make the return line run down hill much better.
I'll see if I can find a pic.
EDIT: Guess I was wrong. I used some sort of 90 deg swivel fitting, and attached the 45 deg fitting to that. Man I wish I saved the parts numbers!!!
Add .orig.jpg to see the pic full size.
Old Oct 27, 2003 | 07:18 PM
turbopimp's Avatar
Default Re: Return fitting question (Flamenco-T)
Don't forget the 2) 8mmx1.25x25 bolts and oil drain gasket...
Old Oct 27, 2003 | 07:20 PM
HXMan's Avatar
Default Re: Return fitting question (turbopimp)
I got a billet flange from http://www.majesticturbo.com/
They have gaskets and bolts too.
Old Oct 27, 2003 | 09:05 PM
Arturbo's Avatar
Better than steak
25 Year Member
You need an oil drain flange:
Old Oct 28, 2003 | 02:06 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Return fitting question (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">You need an oil drain flange:
That's the way mine is set up like Arts.
Old Oct 28, 2003 | 02:43 PM
Mr. Softee's Avatar
i love earls fittings, they are so pretty
kaohli_yang
Nov 18, 2007 05:44 PM
JDMTurboCivic11
Jun 23, 2005 12:41 PM
importboi22
Oct 4, 2004 05:45 PM
untitled
Apr 6, 2004 04:51 PM
harryg
Dec 2, 2003 12:02 PM
