Catch can Question
Old Oct 28, 2003 | 09:30 PM
Excelerate's Avatar
Default Catch can Question
Okay my hometown is the same as Moroso so I figured i go down and talk to the techs in person. They recommended Unit # 85470 for my application, a dry sump breather tank w/ one nipple. The pic below shows you what is included in this package.
So that's the kit. Now the tech guys said i had 2 options. I could plug off the PCV system and use that hose and tee it off with the other valve cover openin for ventine crankcase fumes and send them as one hose into the breather tank. However, that PCV hose is teed off to send a vacuum source to my WG. So i im just gonna keep the PCV system i think cause they said that was alright and just use the other valve cover hose that originally was rerouted back into the stock intake pipe. They said that should be sufficient.. what do you guys think? here are pics of everything.
Now this pic is showin where the exhaust mani ... do you see that gold bolt or plug that is pluggin the mani where a o2 sensor might go... is that gold bolt ok to tap into for an EGT probe?
Last question: do you see where my air filter is goin from the turbo? is that okay for now.. i think im gonna get a super high flow filter by HKS and replace it... i may actually also relocated my battery to behind my passenger side seat. what do you think?
Old Oct 29, 2003 | 08:28 AM
Excelerate's Avatar
Default Re: Catch can Question (6GAccord2.3t)
bump
Old Nov 1, 2003 | 01:07 AM
Excelerate's Avatar
bump
Wazup
Jun 28, 2019 09:33 AM
CiViC I2aCeI2
Mar 14, 2006 02:32 PM
Shizznaz
Feb 25, 2005 06:28 PM
Excelerate
Oct 28, 2003 08:34 AM
Excelerate
Oct 27, 2003 07:18 AM
