MAP problem
Old Oct 26, 2003 | 08:03 PM
kolk1's Avatar
Default MAP problem
I normally dont post much but I have a problem. I cant get rid of Limp mode when i hit boost. I have a Y8 swap in a 91 Si with a T25 home made kit. The shop it is at has been trying to fix it with various Check valves, and all sorts of stuff. The shop wants to fix it without doing the VAFC hack. What i need to know is will a greddy emanage fix this problem? It runs fine until boost when i get a check engine light due to the MAP sensor. The shop said if the Greddy Emanage wont fix the problem they will remove it for no cost. I am good friends with the owner of this shop but im just wondering if this is a waste of my time.This is my current set up to answer some ?
D16Y8, 255 fuel pump, Vortec 12:1 FMU, 320 injectors, AEM fuel rail, AEM fpr, AEM camgear, VAFC.
Old Oct 26, 2003 | 08:06 PM
Ricey McRicerton's Avatar
Default Re: MAP problem (kolk1)
I have the E-Manage and think it's a peice of trash. I would pick that VAFC over the E-Manage anyday. Your problem is that the MAP is not designed to see positive pressure. A Missing Link would solve your problem.
EDIT: The E-Manage will fix your problem though. What happens, is the MAP sensor wire is cut between the ECU and the sensor, is routed through the E-Manage and then back to the stock ECU.
Old Oct 26, 2003 | 08:11 PM
kolk1's Avatar
Default Re: MAP problem (Ricey McRicerton)
well the vafc is installed but even with that he couldnt get it to work.
I havent had my car since april due to alot of problems, and now i need it asap and this is the last problem, if this will work Ill take it. How much is a missing link?
Old Oct 26, 2003 | 08:12 PM
You need to make sure that the MAP part of the VAFC is hooked up correctly. The VAFC should be making sure that your cars ECM is not seeing boost.
Blue94Accord
May 14, 2010 06:46 PM
93TurboSi
Apr 13, 2004 08:29 AM
_VTI-R_
Feb 26, 2003 01:12 PM
LshatchTurbo
Jun 26, 2002 07:48 PM
