Motec Pros only
Old Oct 26, 2003 | 06:02 AM
SpeedDreamz.com's Avatar
Default Motec Pros only
What is the GM part number for the the 3 way boost valve? They have the diagram on their site but no part #
Old Oct 26, 2003 | 07:50 AM
Default Re: Motec Pros only (30psiCiv)
Old Oct 26, 2003 | 08:49 AM
Jared's Avatar
do a search, this has been covered lots of times.
Old Oct 26, 2003 | 09:19 AM
Default Re: Motec Pros only (Jared)
DOnt you think I know that? You try a search and see what you get. I tried every conceivable search with motec and no answers. If it has been covered so many times why dont you know the answer?
Old Oct 26, 2003 | 09:29 AM
Mikeyslude's Avatar
Same one I use with my AEM EMS.
G.M Boost control Solenoid part# 1997152
G.M Pigtail for the boost solenoid part# 12102747
Old Oct 26, 2003 | 09:36 AM
Jared's Avatar
Default Re: Motec Pros only (Mikeyslude)
well lets see, i came up with this:
https://honda-tech.com/zerothread?id=621993
https://honda-tech.com/zerothread?id=603988
https://honda-tech.com/zerothread?id=606437
https://honda-tech.com/zerothread?id=595946
https://honda-tech.com/zerothread?id=575272
https://honda-tech.com/zerothread?id=539036
https://honda-tech.com/zerothread?id=484188
and there were more....
Old Oct 26, 2003 | 09:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikeyslude &raquo;</TD></TR><TR><TD CLASS="quote">Same one I use with my AEM EMS.
G.M Pigtail for the boost solenoid part# 12102747</TD></TR></TABLE>
Thank you for your help. That took alot less time than the previous post.
Old Oct 26, 2003 | 10:11 AM
are any of the capable of 30psi?
Old Oct 26, 2003 | 10:20 AM
Canuk_SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">well lets see, i came up with this:
and there were more....</TD></TR></TABLE>
Mikeyslude's Avatar
Jared, your search was for the gm 3bar map sensor and not the gm 3 way boost controller.
Old Oct 26, 2003 | 10:24 AM
JDogg's Avatar
we are running 28psi with one. there are some supra guys running 30plus
Ihave the map sensor, just need the valve. I got $9.11 at GM Direct, is that right?
Thanks
Old Oct 26, 2003 | 01:20 PM
Mikeyslude's Avatar
yeppers thats the one
UnlimitedHonda5
Aug 20, 2005 06:23 PM
loke
Jun 19, 2004 09:41 AM
boostedcivichatchbacksi
Mar 8, 2004 08:09 AM
Top Ramen
Oct 25, 2003 08:49 PM
