Did a little facelift - pic intensive
This really isn't FI related too much but I'd rather post in here than in appearance/cosmetic. Back in '01 the civic caught fire and did some pretty good damage to the engine bay and one of my fenders as you can see the primer in this pic.
I ended up having to spray paint the entire engine bay when I reconstructed the car, but never got around to painting the new rad support that I welded on. So I figured I'd do it now while getting the fenders repainted.
One can of pep boys body shop paint later it looked like this
Slapped on my freshly painted fenders and now its good to go again.
Re: Did a little facelift - pic intensive (madeiniraq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq »</TD></TR><TR><TD CLASS="quote">how did your car catch fire? pass on the knowlege so nobody has to learn from the same mistake</TD></TR></TABLE>
Also wanna know how it caught on fire
Re: Did a little facelift - pic intensive (Jdm_Rice_Monster)
Lets see here.
Engine:
Bone stock '95 B18b swap
Hondata 2b
Precision 680cc injectors
Walbro fuel pump
3 bar map sensor
Stock ignition
NGK bcpr7es-11 plugs
Spearco intercooler
Custom ic piping
Greddy Type S BOV
MP manifold
T3/04E .63 exhaust, 57 trim compressor
Tial 35mm
2.5" dp to 3" Thermal
Drivetrain/suspension/brakes:
FCC(???) 6 puck clutch disc, ACT HD pressure plate
Stock axles and diff
H&R sports/Koni Yellows
Brembo blank rotors
Axxis Ultimate pads
13/16 master cylinder
Kosei K-1 15x7
BFG Drag radials 205/50/15 fr. Falken Azeni 205/50/15 r.
Electronics:
Autometer boost, EGT, air/fuel guages
Greddy Profec B and turbo timer
Thats pretty much it as far as the important stuff goes. The fire started when I was running 2 additional injectors and an external coil years ago. One of the fuel lines had a small slit in it. Fuel started spraying and got ignited, causing my engine bay to go up in flames. Everything plastic, rubber or wire melted. It was a lengthy repair, but I got it done. All the work was done by myself with the exception of the tuning, which was done by Jeff Evans, and the paint which was done by Larry Verdusco. So far the car is only tuned at 8 psi. I've been having issues with this damn profec b for a while now. I'm pretty sure the solenoid fried when it got too hot in the engine bay from the fire. Anyone know if the actual solenoid is supposed to make a click sound when you switch from high to low boost? I dunno, right now I'm just focusing on getting an EBC that actually works. In December I'm going to try to crack 300 whp with Jeff's help. I'll get some pics up later.
Engine:
Hondata 2b
Walbro fuel pump
3 bar map sensor
Stock ignition
Spearco intercooler
Custom ic piping
Greddy Type S BOV
MP manifold
Tial 35mm
Brembo blank rotors
Axxis Ultimate pads
Kosei K-1 15x7
Electronics:
Spoogen_1
07-31-2005 09:24 AM
