Block Guard
Old Oct 27, 2003 | 01:51 PM
turboZChatch's Avatar
Default Block Guard
Ok I searched and didn't really find what I was looking for I ordered an srp block guard for my turbo ls I will be running 12psi on a stock sleave with just the block guard will this help me or no some say to put it at the top which I feel is useless so I will be putting it more towards the center any help or opinions will be appreciated (not ones that say ohhh 12 psi is going to crack a sleave beacause I ran 14 psi for a long time and had no problem but got boost spike and it hit 21 psi and cracked a ring land)
Old Oct 27, 2003 | 02:41 PM
Default Re: Block Guard (turboZChatch)
nobody has any input??
Old Oct 27, 2003 | 02:53 PM
beerbongskickass's Avatar
Block guards are useless period if you ask me and I would never use one. If your car is tuned properly you shouldn't have a problem running 12 psi.
Old Oct 27, 2003 | 04:36 PM
-iLLuZioN-B18C1's Avatar
Default Re: Block Guard (beerbongskickass)
save your money up for sleeves. if you cant afford it, just go w/o bg IMO. i got one, but if i could do it all over again, i would have definately just saved up a few more months for sleeves but 12 psi should be no problem with piston/rod
Old Oct 28, 2003 | 06:13 AM
Default Re: Block Guard (-iLLuZioN-B18C1)
Thanks guys
Old Oct 28, 2003 | 08:27 AM
green_GSR's Avatar
Boosted cars require thicker sleeves because they need support from top of the sleeves to the bottom. So any block guard is useless. The blockguard itself also restricts coolant flow, so you'll run hot at the top of the sleeves .
Old Oct 28, 2003 | 08:33 AM
LoSt is BlaCk's Avatar
Default Re: Block Guard (green_GSR)
the tune is the key, i run block guards but the never stopped any of my motors from blowing up! although they might add a little strength they are nothing like sleeves!
tonys91tegra
Jul 9, 2009 11:07 AM
Big Bang
Aug 12, 2004 01:38 PM
Kwuaymaikrup
Nov 3, 2003 08:10 PM
SRL
Jul 10, 2003 08:47 AM
BlackGSR
Feb 20, 2002 03:04 PM
