vafc hack screwing with my timing?
Old Oct 27, 2003 | 12:28 PM
othick's Avatar
Default vafc hack screwing with my timing?
I'm running the v-afc hack on my b17 turbo. When I have the base timing set to stock the car hesitates a little between 3500-4500rpm I know this is common when running the hack. I wanted a little magin for safety so I set it back about 3-4 degrees and now it's hesitating at everything between 2500-5500rpm. I'm only running 8psi on 9.7:1 compression so I'm thinking running the stock timing should be o.k. but I've blown motors in the past so I'm a little hesitant to push my luck. If anyone can tell me if they have had reliabiltiy issues with the factory timing settings or what they run for timing I would appreciate it.
Old Oct 27, 2003 | 12:31 PM
99lspwr's Avatar
Default Re: vafc hack screwing with my timing? (othick)
when i had my b17 all stock, it did the same thing....I was always told it was from the way vtec is set up...My girls 97 prelude vtec does the same thing(all stock)...But I know exactly what u are talking about..
Old Oct 27, 2003 | 12:39 PM
VTC_CiViC's Avatar
Default Re: vafc hack screwing with my timing? (99lspwr)
My GSR does the same thing on the hack, though it's more weather dependent than anything, and I run with 2 dergees of retard.
gdrum
Nov 29, 2003 01:31 PM
nigel
Aug 23, 2003 10:32 AM
BoostedMugen
May 31, 2003 02:28 PM
spike
Nov 21, 2002 08:30 AM
