Turbo and compression ratio
Old Oct 28, 2003 | 08:20 PM
WhitEdRift's Avatar
Default Turbo and compression ratio
I don't know a whole lot about where turbo would be best used, but I'm trying to get some info here to make my decision about it. I have an LS, the B18A1 though not the B18B.
I hear from a LOT of people that the LS is the best Integra motor to boost but why? What makes lower compression better than say a higher compression VTEC motor? If higher compression makes more power wouldn't it make more sense that a GSR or a Type R would have greater gains than an LS?
I would appreciate someone clearing this up for me.
Old Oct 28, 2003 | 08:26 PM
TrueNorthStar's Avatar
Default Re: Turbo and compression ratio (WhitEdRift)
You will get more power with the higher compression... But be more prone to detination. So in theory you could run more boost on a lower compression motor and possably make more of a power gain.
As far as the ls being better I would wonder why all the pro teams use Vtec motors instead of ls engines. That is a whole other debate.
Old Oct 28, 2003 | 08:30 PM
Foozball26's Avatar
Default Re: Turbo and compression ratio (TrueNorthStar)
Theres no doubt that the VTEC motors are better to turbo as far as power is concerned.
On the other hand, people like the B18a/b mostly b though b/c it is much cheaper and will usually have more torque while still be safe. Most that use the LS motor are looking for a safe setup etc.
I personally like the torque of the LS, I almost make as much torque as hp.
It all depends on your goals and how deep your waller is.
Old Oct 28, 2003 | 08:33 PM
WhitEdRift's Avatar
Default Re: Turbo and compression ratio (Foozball26)
That's interesting. I had some thoughts on detonation but I wasn't sure.
As for now I am building my engine N/A and getting stronger parts to withstand higher rpm's so hopefully if/when I do get a turbocharger I can run some good boost.
Thanks guys that really cleared things up.
Old Oct 28, 2003 | 09:03 PM
quik sol's Avatar
I am running 9.5:1 b16a3 14 psi daily and love it to death...the lower the compression the better but just dont go TO low or then it will bog...for instance my 8.5:1's were a pain on the street
RGSH22ACCORD
Jun 30, 2007 08:05 PM
b18c5turbo
Jul 15, 2005 02:51 PM
Simple
Nov 10, 2004 07:45 PM
c1v1c_R
Oct 19, 2004 06:20 AM
Flexin5
Aug 31, 2004 02:58 AM
