no charge pipe for 20 mins??
Old Oct 28, 2003 | 10:16 AM
kaj's Avatar
kaj
Default no charge pipe for 20 mins??
in about half an hour i have to drive my car to have the exhaust done. it's a 20 min drive and i have no charge pipe (they will making that for me also).
will the turbo over spool without any kind of back pressure? i don't want it spinning at a million rpm.
thanks
Old Oct 28, 2003 | 10:28 AM
kaj's Avatar
kaj
Default Re: no charge pipe for 20 mins?? (kaj)
anyone??
Old Oct 28, 2003 | 10:30 AM
Boltz's Avatar
if you stay in vacuum id imagine youd be fine, but if you tried giving it boost the wastegate pressure inlet will detect no boost (obviously) and the wastegate wont open, thus making your turbo work hard for nothing
Old Oct 28, 2003 | 10:31 AM
kaj's Avatar
kaj
Default Re: no charge pipe for 20 mins?? (BoostRotter)
but i was thinking the turbo wouldn't be working at all. that's why i was worried about it spinning too much..............?
Old Oct 28, 2003 | 10:37 AM
Mr. Softee's Avatar
Its one of those things where you are not supposed to recommend it but everyone has had to drive at least 5-10 minutes with disconnected charge pipes because in the first few weeks of a new IC piping setup usually one or two blows off. 99% sure you should be fine if you drive it easy mcbeasy. Dont hold me to it though!
Old Oct 28, 2003 | 10:39 AM
twkdCD595's Avatar
I would think it would overspin even if you stayed in vaccum... there is no boost to read without the piping connected to be charged.
maybe if you could force the wastegate to stay open it would help.
Old Oct 28, 2003 | 10:40 AM
brkrnu's Avatar
Default Re: no charge pipe for 20 mins?? (twkdCD595)
I drove mine like that for a week with no problems.
Sounds kinda like a vacuum. Listen closely to the sound to know how hard to press it.
Old Oct 28, 2003 | 10:57 AM
turbopimp's Avatar
no need to worry about overspinning the turbo since the charge pipes are not connected, there is not enough exhaust volume to drive the turbo to overspeed
Old Oct 28, 2003 | 11:04 AM
genop's Avatar
Default Re: no charge pipe for 20 mins?? (turbopimp)
couldnt you just unhook the wastegate?
Old Oct 28, 2003 | 11:09 AM
redline201's Avatar
Default Re: no charge pipe for 20 mins?? (genop)
i had some tuning problems and i had to make an hour and a half drive home
i didnt wanna go into boost cause i was running my stock ecu and injectors so..
we took out the wastegate spring
sure it sounded like a diesel truck
but it worked fine
Old Oct 28, 2003 | 11:11 AM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaj &raquo;</TD></TR><TR><TD CLASS="quote">in about half an hour i have to drive my car to have the exhaust done. it's a 20 min drive and i have no charge pipe (they will making that for me also).
thanks</TD></TR></TABLE>
You should be fine driving it there as long as you stay below 3K rpm... I had to drvie mine like this as well, and everything was fine... You do have a downpipe though right...? I wouldn't drive without a downpipe...
Old Nov 6, 2003 | 09:11 AM
DeadLock23's Avatar
well I kinda have the same situation, except I need to drive about 1.5 hours
i have a gsr charge pipe and it wont fit my ls properly, so i was just gonna put the short ram intake on and drive without a charge pipe.
plus my DP is also for a gsr so its like 2 inches too short, so it doesnt connect to the cat
should i do this? or get it towed? without the charge pipe you can't read vacume?
Old Nov 6, 2003 | 07:35 PM
kaj's Avatar
kaj
Default Re: (DeadLock23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadLock23 &raquo;</TD></TR><TR><TD CLASS="quote">well I kinda have the same situation, except I need to drive about 1.5 hours
should i do this? or get it towed? without the charge pipe you can't read vacume? </TD></TR></TABLE>
you can read vaccum without a charge pipe. your boost gauge should be connected to a vaccum line after the the throttle body anyway, right? it'll work. i drove mine to the shop with an open d/p as well. i had to have them weld me an entire 3" exhaust as well as my charge pipe. it was only a 20 min drive through town though. an hour and a half is pushing.. especially if you're gonna be driving on the freeway, which is sounds like you are?
just to let ya'll know: i drove the car, kept it under 3k and it was fine. never spooled more than normal. i figured it would be okay.. but always a good idea to ask first.
Old Nov 11, 2003 | 07:26 AM
integra-modder's Avatar
As long as you have a downpipe that gets the bulk of the gases away from the turbo and the block, then you should be fine...just try to go on a cold day and dont go too fast...
Old Nov 11, 2003 | 07:32 AM
VTC_CiViC's Avatar
Default Re: (integra-modder)
I drove from my home to Miami muffler (15min) with no charge piping as well. Took as many small side roads as I could to avoid traffic so I could crawl at a snails pace without spooling the turbo. It's not easy but it works.
kte324
Jan 30, 2010 06:04 PM
K i l l a B e e.
Jan 22, 2009 08:11 PM
Vtecme92
Apr 22, 2006 02:00 PM
chihuahuamanx
Feb 23, 2005 11:34 PM
ownedbyvtec
Mar 27, 2004 08:02 PM
