Part # for 3 bar pigtail
I picked up a GM 3 bar map sensor for my d16y7 and was wondering what the part number is or what i ask for as far as the pigtail goes when I go to Napa. Thanks,
Pfieff
Pfieff
You can also just go to your local Pep boys or autozone and pick up the Pigtail for the MAP sensor. The company is called Conduct-Tite and the P/N: is: 85115, $9.99. It will be labeled as a pigtail for a GM map sensor. They usually don't keep them in stock, but they can be ordered.
The pigtail they usually keep in stock and also works is a GM throttle position sensor harness. This is also made by Conduct Tite and will also cost you about $10 dollars. The only difference is that you will have to cut out the slots so it fits properly. It will take like a minute to do and fits perfect. Good luck
Guest
Posts: n/a
I got mine from http://www.gmpartsdirect.com
and i used pn#12085502
like $23 after shipping and stuff
ForceFed Motorsports
Mar 7, 2008 03:57 PM
