Spool on SC-61
Old Oct 29, 2003 | 09:43 AM
30psi Teg's Avatar
Default Spool on SC-61
I was wondering what RPM you guys running a SC-61 will see lets say about 15psi. It is on a 1.8 LS motor w/ ported head and bigger cams and valves.
Old Oct 29, 2003 | 10:31 AM
Cyphear's Avatar
Default Re: Spool on SC-61 (30psi Teg)
what a/r? and is it a t3 or t4?
Old Oct 29, 2003 | 10:34 AM
30psi Teg's Avatar
Default Re: Spool on SC-61 (Cyphear)
my bad, its a T3 .63 ar. exhaust and .70 (i believe) T04S compressor housing.
Old Oct 29, 2003 | 10:55 AM
hybrid901's Avatar
10psi around 4-4500k
Old Oct 29, 2003 | 10:57 AM
SpoolnG2's Avatar
Default Re: Spool on SC-61 (hybrid901)
I'm assuming your keeping your stock compression on the block? 9.2:1 ? And on the turbo your gonna be using the T350 76 trim ?
Old Oct 29, 2003 | 11:10 AM
30psi Teg's Avatar
Default Re: Spool on SC-61 (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming your keeping your stock compression on the block? 9.2:1 ? And on the turbo your gonna be using the T350 76 trim ?</TD></TR></TABLE>
Yep but actually my compression is around 8.8:1 probably not a huge diff though
Old Oct 29, 2003 | 11:24 AM
SiRkid's Avatar
on a 1.8l? id say 5k full boost.
hybrid..your 2.0l right?
Old Oct 29, 2003 | 11:32 AM
30psi Teg's Avatar
Default Re: Spool on SC-61 (SiRkid)
cool thats what I thought, that it would be about 500-750rpm higher than my 50 trim t3/t4. But the guy who was helping me tune thought it was spooling slow. cool thanks for the info
Old Oct 29, 2003 | 11:36 AM
teamrocket si's Avatar
7psi by 5000rpm
B18_DrpD
Nov 18, 2004 04:46 PM
untitled
Aug 28, 2003 12:16 PM
Chrome Pipes
Jan 21, 2003 09:21 PM
Gearheaded
Nov 2, 2001 10:31 AM
