Heat protection for hood....
Does anyone out there run any kind of insulation on the hood above their turbo to protect the paint?
What did you use and where did you get it? I was thinking about trying to find something similar to what is found under DSM hoods above the turbo and manifold.
i HAS questions ?
Re: Heat protection for hood.... (HXMan)
Check out this stuff. http://www.mmrusa.com/HSreflectcloth.htm. Kind of expensive, but it'd get the job done. They also sell Reflect-a-shield which is used a lot of times to insulate around catalytic converters and such.
Re: (Paul_Vang)
summit sells one that protects up to 1000 degrees on one side and 2000 degrees on the other depending which side you want to use and its made by DEI it comes in 36"x40" sheet and is 55 bucks, seems alright to me....
Re: (buh_buh)
Go to any hardware store and pick up insulated foil pipe wrap. It's adhesive on one side, and can withstand 400+ temps. The kind I bought came in a 8"x10' roll and it was like $9.99 or something, Works good.
Re: (buh_buh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buh_buh »</TD></TR><TR><TD CLASS="quote">would something like this work?
I think I will use this idea.
Re: (buh_buh)
someone should chime in, but i hear those break
also in my car, the manifold is the hottest part of the exhaust system and heats up the hood severely...
i need to wrap my manifold
I want a CRX tattoed on my butt
Re: Heat protection for hood.... (boostdummy)
can you touch your exhaust manifold after driving with heat wrap? how much does it cool it down is what i need to know
Re: Heat protection for hood.... (CanadianMade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanadianMade »</TD></TR><TR><TD CLASS="quote">can you touch your exhaust manifold after driving with heat wrap? how much does it cool it down is what i need to know</TD></TR></TABLE>
I have my manifold heat-wrapped and I can touch the manifold after driving - the stuff works wonders on under-hood temps. The only side effect is that my engine takes about 3x longer to heat up when it's really cold outside, but I'll deal with it
Just so some of you know, cast manifolds are known to crack if heat-wrapped. heat cant escape and it will crack were the manifold gets the hottest usually.
Location: The Village Hidden in the Leaves: Seattle, WA
Re: (buh_buh)
I HAD A FEW OF THESE MADE. pretty much like ATP's, but just not polish. if you're interested, give me an IM.
Re: Heat protection for hood.... (stockredej1)
this is stainless steel though, not cast
BUMP for some info on how much it reduces heat
Ive also got a question, say I have a bunch of header wrap left over, can I put strips long my hood where the mani is close? Or would that somehow work against me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanadianMade »</TD></TR><TR><TD CLASS="quote">Ive also got a question, say I have a bunch of header wrap left over, can I put strips long my hood where the mani is close? Or would that somehow work against me?</TD></TR></TABLE>
Just get some heat shield for under the hood from DEI, worked for me
http://www.designengineering.com/products.asp
Sorry about the crappy pic
Re: (buh_buh)
I've got one of those on my Maxima, the turbo sits really high, so I wanted to protect the paint on the hood. Doesn't really seem to do much, but at least it looks nice and hasn't broken yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanadianMade »</TD></TR><TR><TD CLASS="quote">this is stainless steel though, not cast
Ive also got a question, say I have a bunch of header wrap left over, can I put strips long my hood where the mani is close? Or would that somehow work against me?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanadianMade »</TD></TR><TR><TD CLASS="quote">this is stainless steel though, not cast
