junkyard turbo question
Old Jan 27, 2004 | 06:12 PM
m3bluegsr's Avatar
Default junkyard turbo question
Ive searched and just have one quick question. Are the 14b and the t25 dsm turbos internal wastegate set at 6 or 7 psi. if not how do i limit them. thanks
Old Jan 27, 2004 | 06:20 PM
SOFLSOL's Avatar
Theyre at 8psi. The ecu bumps the boost to like 11-12psi on the dsm's.
Old Jan 27, 2004 | 06:27 PM
Adriano's Avatar
Default Re: (SOFLSOL)
I dont know what's the w/g setting, but the 1G (14b) runs 12lbs stock and the 2G (t25) run 14.7lbs stock. I'm pretty sure those are the stock w/g setting.
Old Jan 27, 2004 | 08:30 PM
SOFLSOL's Avatar
Default Re: (brryder)
stock wastegate is 8psi on both. I run a 14b 8psi daily on stock wastegate.
Old Jan 28, 2004 | 03:35 AM
T-RO's Avatar
Yes for the 1,000,000,000 time, DSMs run 8psi on a non-DSM car.
You can lower that by using the "carb spring" method, or cutting the wastegate arm.
Look in the Forced Induction section of http://www.homemadeturbo.com and they have a great FAQ there.
1995civicEJ
Feb 5, 2007 07:25 AM
SlowSOHC-T
Aug 9, 2006 04:39 PM
taejin11
May 3, 2004 12:24 PM
turbodelsolman
Mar 13, 2003 08:07 PM
