Anyone test this before? Pre spooling Nitrous
Old Jan 25, 2004 | 07:51 PM
VNTEC's Avatar
B A N N E D
Default Anyone test this before? Pre spooling Nitrous
http://cgi.ebay.com/ebaymotors...38634
"The Speednosis PRE-spool switching system allows your nitrous system to spray as your Turbo is building boost. Also works great with your Supercharger for huge low end power gains. It will control any existing nitrous system. The PRE-spool system is easy to adjust with an allen key from 4-15 psi, and is completely automated once activated.
The PRE-spool switching system is first full throttle activated, then boost level deactivated. This allows you to spray nitrous until you reach your desired boost setting and nearly eliminate ALL your Turbo lag times. Not only will this type of nitrous use make huge track and road course gains. This system will actually save you a TON of time and money on nitrous refills.
PRE-spool comes with everything you will need to install it. The PRE-spool system supports wet or dry nitrous systems. You can control either a single nitrous solenoid or nitrous and fuel solenoids. Includes a detailed wire diagram, install is simple."
Old Jan 25, 2004 | 07:56 PM
tegasaurus's Avatar
Default Re: Anyone test this before? Pre spooling Nitrous (VNTEC)
why spend $50 on a pressure switch? Couldn't the same thing the acheived by simply having a pressure switch that cuts current to ur nitrous sytem at X psi? however it does look like a good idea for those who are looking for a decrease in lag time with their sc63s etc
-Ryan
Old Jan 26, 2004 | 02:05 PM
b18cls1's Avatar
Default Re: Anyone test this before? Pre spooling Nitrous (tegasaurus)
that trick has been arround awhile. most people just ue a small 50 shot or so hard wired not on a micro switch just a push button to spool large turbos at the lights fo no lag.
5LuGinTeg
Sep 10, 2014 11:56 AM
genia
Oct 14, 2007 07:39 PM
done
Jun 25, 2006 08:30 PM
myNAteq
Jul 25, 2001 03:14 PM
